HD15 OR USB FOR FANE SV. LF600?
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=93166
Printed Date: 27 March 2026 at 2:16am
Topic: HD15 OR USB FOR FANE SV. LF600?
Posted By: PirateAlien
Subject: HD15 OR USB FOR FANE SV. LF600?
Date Posted: 02 September 2015 at 7:39pm
HI THERE!
I have a little big question and I thing here is the place to ask! :)
Recently I change the drivers of two double 15' bass reflex who I have and I use a Fane Sovereign LF 600w.
Sounds nice used like bass (down to 120hz) but normaly I use for a "kickbass" (from 120hz to 300/400...) the freq. of this drivers is 37 to 3000hz.
for the moment everything is good if not because they are very old boxes of bad wood (MDF) and begin to break little pieces with grated of use, etc...
Then I start to planing about make a new model for this drivers and change it to a HD215 or a USB... I need to look it well with a friend but if somebody knows what is the best option for this drivers? will be a nice help, I also think about readaptate a USB or HD15 box for these drivers,, but I need to know if it's a good choice for this cabinets! any opinion or help will be cooool!!! Thanks to all!!
Posted By: all bass
Date Posted: 02 September 2015 at 11:52pm
If it needs to go up to 3-400Hz it's going to have to be a reflex box.
Both the HD15 and the USB(which uses an 18" driver) are band pass horns and will not sound good >180Hz.
