A very special disco rig..........
Category: Other Chat
Forum Name: Golden oldies
URL: https://forum.speakerplans.com/forum_posts.asp?TID=93317
Printed Date: 26 March 2026 at 5:40pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: A very special disco rig..........
Posted By: L8 ECU
Subject: A very special disco rig..........
Date Posted: 20 September 2015 at 12:37am
My first post, lots of images to show you........ It's a very special disco rig (front end) that dates back to 1975, and was used at least once a week for over 16 years. First image.......(loads more to follow), in storage and cased up. Has been in storage in Somerset for many years:
Posted By: L8 ECU
Date Posted: 20 September 2015 at 12:44am
Posted By: matty w
Date Posted: 20 September 2015 at 1:01am
Nice cases :D
------------- Black to black , red to red , blue to bits ....
Posted By: L8 ECU
Date Posted: 20 September 2015 at 1:20am
matty w wrote:
Nice cases :D |
Thanks. The original cases were by Packhorse and blue. The cases pictured were made in 1992.
Posted By: L8 ECU
Date Posted: 20 September 2015 at 1:34am
The self-op / engineers desk in detail:
Posted By: L8 ECU
Date Posted: 20 September 2015 at 1:54am
The DJ / presenters mixer in detail........bare minimum of controls! Notice no gain trim, just a fader and PFL for each input.......then remote machine starts, talk-back & metering.
Posted By: L8 ECU
Date Posted: 20 September 2015 at 2:05am
The usual stage layout..............
Posted By: L8 ECU
Date Posted: 20 September 2015 at 2:25am
Some general info....... The images above show the mixers and turntables that enabled the broadcast of Funk / Jazz-Funk and Soul music on medium-wave (and in later years FM) on a weekly basis for over 18 years. It could be said that millions of people listened to the output from the equipment! Originally the Friday night broadcasts were from the Empire Ballrooms (London), then for many years the venue would have been the Lyceum in the Strand (also London)........ In later years, there were many OB's from venues outside of central London. The equipment pictured above was always used with a very nice PA system........more details to follow in later posts.
Posted By: shagnasty
Date Posted: 20 September 2015 at 3:07am
Absolutely Awesome!!!! Would love to see some pics of the rig in action, all multipin'd up, proper tour spec mentally, doubtless the best sound you can get from a disc to output...... Awesome!
Posted By: Pinyorouk
Date Posted: 20 September 2015 at 7:22am
An absolutely beautiful system. I would pay to play some vinyl on such a setup. May you please take some pictures of the eq section and possibly the internals. Is the mixing board powered by an internal or external power supply? Who built this system and what type of turntables are these? I am impressed!
Posted By: all bass
Date Posted: 20 September 2015 at 8:16am
Abolute beauty!
Please tell me this rig still gets out sometimes...
------------- https://www.instagram.com/my_modular_journey/
Posted By: L8 ECU
Date Posted: 20 September 2015 at 8:44am
shagnasty wrote:
Absolutely Awesome!!!! Would love to see some pics of the rig in action, all multipin'd up, proper tour spec mentally, doubtless the best sound you can get from a disc to output......Awesome |
I will find some black & white images and post up......but yes, this OB set-up was very high quality. Incredible sounds. The sound / tech performance had to good, as this was in the days of IBA "code of practice", when ALL ILR studio output (including outside broadcasts) had to be to a set (and very strict) minimum standard! The custom desks were made by Raindirk (Norfolk or Suffolk based IIRC)........google Raindirk to see their impressive client list. NO IC's in the audio signal path, all discrete components. These desks ran warm / very hot - especially the engineers desk.
Posted By: L8 ECU
Date Posted: 20 September 2015 at 9:01am
Pinyorouk wrote:
An absolutely beautiful system. I would pay to play some vinyl on such a setup. May you please take some pictures of the eq section and possibly the internals. Is the mixing board powered by an internal or external power supply? Who built this system and what type of turntables are these? I am impressed! |
As per above post, great sounds, proper analogue warmth and amazing clarity! Desk manufacturer Raindirk knew what they were doing. Even the CAP RAD custom built "gram amps" (RIAA pre amps) housed within the turntable flight-cases were special! Yes, external PSU.....for both desks. Turntables are Technics SP-10 Mk2. Modified by CAP RAD engineering dept. Original cartridges would have been Sure SC-35.........there was not a lot of choice back then! The Ortofon carts were fitted soon after they became available - perhaps late 80's / early 90's.
Posted By: wiz247
Date Posted: 20 September 2015 at 9:11am
Wow!! This is high-end shiznizz...Considering their age and the environment the were used in, they look in top notch condition.
Posted By: L8 ECU
Date Posted: 20 September 2015 at 9:22am
all bass wrote:
Abolute beauty!
Please tell me this rig still gets out sometimes... |
This rig has not been used for many years! I purchased it from Cap Rad mid 90's........By that time the disco "thing" had all but gone out of fashion. The later gigs for this OB rig were the "best disco out of town" series (DJ Phil Allen)...... Finally, Chris Tarrant did many breakfast show OB's specials using this rig from many counties around the world........... At this stage I had already purchased the pictured OB rig from CAP RAD and was hiring it to them! This was because the replacement Tweed Audio desks were "late" on being delivered. Ironically, the Tweed Audio replacement desks were not used much, as by that time most ILR stations were in big troubles financially. OB's and engineering dept staff were the first thing the accountants would axe.
Posted By: colint
Date Posted: 20 September 2015 at 10:42am
L8 ECU wrote:
all bass wrote:
Abolute beauty!
Surly you mean Mike Allen? who also supplied the Martin Audio system for "the best disco in town"
------------- Never criticise another man until you've walked a mile in his shoes. Once you have, call him what you like, you're a mile away and you've got his shoes!
Posted By: L8 ECU
Date Posted: 20 September 2015 at 10:44am
About the PA System (not owned by me) that was used with the pictured OB kit: Alchemy .........when you mix a few things together, and great things happen. Mid to late 70's were early days for London's Capital Radio....... It was also early days for a then little known PA manufacturing company based just 200 yards away from Capital's studios at Euston Tower: Martin Audio (Stanhope Street). Then you add a Capital Radio DJ that was into audio gear: Mike Allen. Mike heard and purchased the classic Martin Audio 4k watt rig, comprising 8 x 115 bins / 4 x philishaves / 4 x martin horn h/f + JBL bullet packs........ This rig was to be used for many years on a weekly basis for the "Best Disco In Town" gigs. I knew Dave Martin (as I made some proto-type cabs for him), he said Mike Allen was treated to a fairly short (and loud) demo of a single stack at the Stanhope Street factory and immediately ordered the 4k system. Back then, perhaps 4k watts was not considered to be a "big" PA system, but it was huge power for a disco rig! Tony ASS may confirm, but I do not think Froggy (respect is due) was on the scene at that time. How did it sound? Well the first time I heard this was at the Lyceum with THAT high quality front end (as pictured on page 1) I was stunned. Simply amazing "in yer face" full bandwidth audio at very high SPL's. You tend not to forget moments like that. More info in later posts about MARS (Mike Allen Rental Services) the Martin rig, amps and the great road crew that he employed to maintain and set up the rig.
Date Posted: 20 September 2015 at 10:50am
Thank you for an insight into some very fine historical history. My next question would be how much did it cost but I'm sure you won't tell me
Posted By: L8 ECU
Date Posted: 20 September 2015 at 11:17am
Pinyorouk wrote:
[QUOTE=L8 ECU][QUOTE=Pinyorouk]
Actually, I honestly cannot recall how much I paid. Was quite expensive, as I was bidding against at least one other party.
Posted By: colint
Date Posted: 20 September 2015 at 11:39am
That is some very impressive kit for sure lovely condition too.
Posted By: L8 ECU
Date Posted: 20 September 2015 at 11:42am
[/QUOTE] Surly you mean Mike Allen? who also supplied the Martin Audio system for "the best disco in town" [/QUOTE]
Confusing, but Phil Allen was a Capital Radio presenter who did late night/early morning soul / funk shows - great presenter. He had no connection with the equipment pictured, or any connection with the PA system, except for using it for outside broadcasts (Best Disco Out of Town).
Posted By: colint
Date Posted: 20 September 2015 at 11:55am
Ah a case of too many Allens Lol. Mike's was the first really big system I heard (at the Lyceum) like you I was gobsmacked at the quality and power of that system.
Posted By: L8 ECU
Date Posted: 20 September 2015 at 11:57am
Pinyorouk wrote:
............May you please take some pictures of the eq section and possibly the internals......... |
See below for EQ pics. Internals pics are tricky as I have put it all away in the cases. It is mostly hard wired, with all modules shielded from each other. If I get time will take internal pics.
Posted By: jammin75
Date Posted: 20 September 2015 at 12:01pm
nice post
------------- feel the vibes !!! "Who Feels it Knows it" Strong like Lion
Posted By: app
Date Posted: 20 September 2015 at 2:15pm
What a beautiful thing it is!
Can imagine the sound quality of the machine...
------------- "what!?"
Posted By: mini-mad
Date Posted: 20 September 2015 at 2:30pm
I'll sit and wait for internal pics.....
I do like wen peeps throw up pics of the guts of their hardware.
------------- If it sounds like a gorilla is trying to escape, turn it down.
Posted By: L8 ECU
Date Posted: 20 September 2015 at 3:34pm
Two scanned images from the Capital Fun Book, 1977 - 78Notice the mic arm. Made in-house by Cap Rad engineering dept. Milled from aluminium, a proper work of art. Will try to find it and post close-up images of it. It's hiding in one of the milticore flight-cases....... Left pic: Mike Allen Right pic: Peter Young  Top: Mike Allen............Middle: Greg Edwards........Bottom: Graeme Dean
Date Posted: 20 September 2015 at 4:48pm
Lovely system L8,well done Sir.
Re Froggy,he was using the matamp/Orange rig from around 1971-79,the big ASS rig first appeared late '79 early 1980.
------------- Be seeing you.
Date Posted: 20 September 2015 at 5:14pm
Buitifull piece of Vintage machine there,
love to hear that
nice and refreshing upload!!
------------- Musical Roots Reggae Vibration is Life! for music is sound...sound is vibration...vibration is energy... and energy begets life. Therein lies my passion!...MUSIC IS LIFE...
Posted By: njw
Date Posted: 20 September 2015 at 8:21pm
Superb! And spot the Martin 'M' in the photo above.
Posted By: L8 ECU
Date Posted: 21 September 2015 at 5:18pm
OK, just spoken to Jerry Eade (one of the soundmen for MARS back in the day)...... The first amps they used with the Martin rig were Phase Linear. They were soon replaced by Crown DC300A 's (for mids & highs) and BGW's for bottom end. A few years onwards, and they were using Crown PSA 2's...... By that time they were doing outdoor gigs too, like Pickets Lock Centre (north London), and Leatherhead Leisure centre (Funk & Soul alldayers). When you look at amplifier power outputs of that era, the Martin Audio kit HAD to be high sensitivity / horn loaded throughout. Without a doubt Dave Martin was "on the ball".
Posted By: SamV
Date Posted: 21 September 2015 at 7:51pm
Posted By: madboffin
Date Posted: 11 October 2015 at 1:13am
Just spotted this thread, as I haven't read this message board for a while...
If I remember rightly, the MARS rig was eventually sold to Capital Entertainments (nothing to do with Capital Radio, and the original partners in Cap Ents eventually divided up the company to form Capital Sound and Encore) and incorporated into their large Martin Modular rig. Later on, at the end of the 1980's, Capital sold off all their Martin Modular kit when they bought the first F2 system. I think it ended up somewhere in Africa.
I have a copy of the original IBA CoP somewhere - now that's what's really meant by "Broadcast Spec" . It wasn't long before the broadcasters were lobbying hard to get it watered down...
Posted By: L8 ECU
Date Posted: 11 October 2015 at 1:24pm
If I remember rightly, the MARS rig was eventually sold to Capital Entertainments (nothing to do with Capital Radio, and the original partners in Cap Ents eventually divided up the company to form Capital Sound and Encore) and incorporated into their large Martin Modular rig. Later on, at the end of the 1980's, Capital sold off all their Martin Modular kit when they bought the first F2 system. I think it ended up somewhere in Africa |
Nowadays we know them as "Capital Sound Hire", the Merton / Wimbledon based company run by Keith Davis. I heard the complete MARS Martin rig was sold to a PA company in Italy. This would have been because Capital Sound needed to make room for the RS1200 stock that was to be the new standard in quick rigging flown PA. I may visit or phone Keith during the week find out for sure. Having moved to Somerset, I have not seen or spoken to Keith Davis for over 20 years.
Posted By: L8 ECU
Date Posted: 11 October 2015 at 1:49pm
Searching google images..........found 2 more pictures of the rig........Early pre flightcase days (Adrian Love)...........and then in the original blue Packhorse cases (Mick Brown):
Posted By: L8 ECU
Date Posted: 11 October 2015 at 1:54pm
Posted By: Nick Sasquash
Date Posted: 11 October 2015 at 10:28pm
quailty post / thread :-)
------------- https://operationsoundsystemrecords.bandcamp.com/
Posted By: L8 ECU
Date Posted: 12 October 2015 at 4:05pm
Thanks for all the kind comments. Spoke with Keith Davis today (Capital Sound Hire), he is 100% sure the MARS Martin rig was sold to a customer abroad, but cannot recall the country. Original owner of the PA system (Mike Allen) may know, but sadly it's not possible to ask him.
