new build, almost finished
URL: https://forum.speakerplans.com/forum_posts.asp?TID=94148
Printed Date: 26 March 2026 at 11:31pm
Topic: new build, almost finished
Posted By: johnEcash
Subject: new build, almost finished
Date Posted: 15 December 2015 at 11:03am
Hi all,
A few months ago I started to build my own soundsystem with a friend of mine, it consists of 2 Double 15 inch wbins (800 w) and 12Inch mid + top
just finishing up the paint and we are ready to roll
Posted By: AlmostSalty
Date Posted: 15 December 2015 at 11:10am
Nice build! Clap
Date Posted: 15 December 2015 at 11:24am
Thanks,
the white areas on the bottom speaker are primer and will be painted black 2nd sub will be paibted the same
Posted By: bob4
Date Posted: 15 December 2015 at 11:41am
nice to see someone build something off the beaten path! Clap
How about handles on the wbins? They look like they're a bunch of heavy f*ckers!
EDIT: Germany? Embarrassed
EDIT 2: which drivers are going in? Big smile
Posted By: Timebomb
Date Posted: 15 December 2015 at 11:43am
Nice!  Is this your own design? i dont think ive seen that layout before.
Posted By: bob4
Date Posted: 15 December 2015 at 11:47am
How high are you going to run the wbin? I guess you chose it to avoid seperate kick bins? Thumbs Up
Posted By: bob4
Date Posted: 15 December 2015 at 11:56am
This plan has a similar layout: http://www.dancetech.com/aa_dt_new/pa/plans/2x15-folded-print.gif" rel="nofollow">http://www.dancetech.com/aa_dt_new/pa/plans/2x15-folded-print.gif
not from germany, belgium :p
we have a handle bar at the top of the wbins and we will add weels so we don't have to lift them as much.
They weigh +-60 kgs without the speakers.
the drivers we are using are:
eminence delta 15lfa for wbin
eminence Kapa 12 mid
jbl compression driver highs
probably like the last picture, me might build some extra kickbins in the future, but for now this is how we want to run it.
you think stacking 2 wbins like this would raise the 2nd one up too high? still learning what the best positioning is for these
Date Posted: 15 December 2015 at 11:58am
yeah looks like the same design indeed
Posted By: bob4
Date Posted: 15 December 2015 at 12:00pm
Tongue
ouch! Ouch
I was talking about the crossover frequency between the cabs Smile
Nice and simple little sound! What style of music will you play?
Date Posted: 15 December 2015 at 12:05pm
aah i got you
 w bins
Cut-off lower: 38hz / 24 db
upper: 140hz/24 db
tops:
upper: 20khz /24db
lower: 140hz/24db
the music we will be playing is tekno, acid, hardcore, tribe.
we want to start some free party raves over here :p
Posted By: bob4
Date Posted: 15 December 2015 at 12:12pm
Hmmmm, I wonder if the cab could be redesigned for PPSL loading Evil Smile
but maybe the front chamber would become too big.....Confused
Posted By: bob4
Date Posted: 15 December 2015 at 12:14pm
aah i got you
 w bins
upper: 140hz/24 db
tops:
upper: 20khz /24db
lower: 140hz/24db
Sounds good.
It will probably fit that style of music well!
Have you tested the wbins  yet?
Date Posted: 15 December 2015 at 12:18pm
checked a bit further and the dimensions listed above are the same as ours (not 100% sure about horn), we just left the back corners on our cabinet.
Posted By: bob4
Date Posted: 15 December 2015 at 12:27pm
I have no experience of these wbins, but I suppose a short front loaded horn like this should kick well enough (but yes, that's only a guess). On Dancetech a lower cutoof of 55 Hz was mentioned, so it would probably be lacking in the subbass department if anywhere. That would be a problem with roots and dub, but probably works fine with techno Big smile
If the stack is not high enough, you could rotate the upper wbin 90 degrees to get the midtop higher. Or maybe even rotate both wbins if you need to get a lot higher! Don't forget to use a ratchet strap though to fix the stack.....
Date Posted: 15 December 2015 at 12:34pm
thanks for the info man,
what we need now is a crossover + eq or a processor (and yes the rest of the paint needs to be done) and we are running.
amps are qsc gx5 for the top and gx7 for the bass cabs
