Enclosure to load Oberton 12MB35
Category: Plans
Forum Name: Plan Requests
Forum Description: All plan requests here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=94738
Printed Date: 27 March 2026 at 8:18am
Topic: Enclosure to load Oberton 12MB35
Posted By: bozhidar
Subject: Enclosure to load Oberton 12MB35
Date Posted: 14 February 2016 at 6:09am
WHat in your opinion is my best option?
I am trying to figure out my way thru WinISD to generate a reflex box but I am not very sure of the final results..
They will play 200 hz - 1000 hz, above I will have a compression driver.
http://www.oberton.com/index.php?option=com_content&view=article&id=386:12b450&catid=49:ferrite-loudspeakers" rel="nofollow - Here are the specs of the driver.
Posted By: DJ-Versatile
Date Posted: 16 February 2016 at 10:53pm
Just popped it in quickly and pressed optimum, remember you can change the lengths of each side of the cabinet to suit you, as long as you compensate for it to keep the volume the same.
With this cabinet you'll need 3 ports 47mm diameter 13.14cm long giving you a vent mach of 0.07
Now i'm no genius when it comes to designing cabs so there may be other options.
http://s1030.photobucket.com/user/Lewis_Corbin/media/Oberton%20design_zpszcowvafd.jpg.html" rel="nofollow">
Can I ask why you are using this particular driver? 700w seems a bit excessive for a 12" seems like you're really going to have to drive it to get anything good out of it.
If you are the smartest person in the room, you're in the wrong room....
