Cabinet ID
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=94759
Printed Date: 27 March 2026 at 11:09am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Cabinet ID
Posted By: tekcsedi
Subject: Cabinet ID
Date Posted: 15 February 2016 at 5:18pm
Trying to figure out what these cabs are.From what i can tell they are similar to the turbosound tsw118,only 15 inch.The seller does not know much about them.Any ideas?
Posted By: tv00
Date Posted: 15 February 2016 at 5:25pm
They sure look like some bph, so don't expect much below 50 hz
------------- www.facebook.com/babysoundsystem
Posted By: tekcsedi
Date Posted: 15 February 2016 at 5:29pm
I reckon they'll drop a bit lower coupled properly with some HD15's.Seller is asking for around 200 euros complete with some eminence drivers from what I can tell.Think I'll scoop em' up
Posted By: tv00
Date Posted: 15 February 2016 at 9:16pm
Do a simulation, I doubt going lower than 50 hz, but ok if they're FAR bigger than hd15 perhaps yes. Good coupling between different boxes at more than xover point is not always easy / impossible if delay curves are not similar.
Remember you need something like a stack of 6 hd15s to reach down to I think 53hz (read plan)
Posted By: tekcsedi
Date Posted: 15 February 2016 at 9:20pm
Changed my mind on these after all, got offered some 1850 for a good price.Same thing applies, I presume.
And I have not much need for sub 50Hz sound, as I play mostly kick oriented stuff.Thanks for the input.
Posted By: tv00
Date Posted: 16 February 2016 at 10:54am
OH, these 15" bph must certainly have a hard kick! I meant from 50hz & UP! 100 hz should be really loud from them as the cabinet is working as a horn, not bandpass, this gives much more sensivity & less excursion is needed per Db in general (does not always apply)
On the other hand if you have hd15s already you should have kick !
Is it a 1850 horn? It's not a really "sub"sub either, kicks in around 45 hz...
