12" Kick/LowMid 90-600 Hz Cabinet?
Category: Plans
Forum Name: Plan Requests
Forum Description: All plan requests here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=95875
Printed Date: 27 March 2026 at 9:30am
Topic: 12" Kick/LowMid 90-600 Hz Cabinet?
Posted By: Diaz
Subject: 12" Kick/LowMid 90-600 Hz Cabinet?
Date Posted: 29 May 2016 at 5:46pm
Hi, im searching for a compact 12" Cabinet to be used with my Oberton 12B450.
It should have max output & clarity between 90-600 Hz.
Underneath i use my EV T18 (w/ PD186) as Kickfills from 65-90Hz.
From ~550 Hz upwards i use a 2" Selenium D405.
Also on Hornplans i only could find Cabinets that are good from 200Hz upwards (mainly horn concepts). All the 12" Bass cabinets i could find only play till 150hz max.
What about Bass Reflex Cabinets?
Thank you in advance.
Posted By: Shortrope
Date Posted: 29 May 2016 at 8:21pm
Get on Winisd and design something for yourself, it's not to difficult.
Posted By: Diaz
Date Posted: 29 May 2016 at 9:20pm
thank you for your fast answer. what do you have to pay attention with?
you design the box around the speaker with the t&s parameters an the volume given?
i would love to have a design where i can put the 12" and the 2" in one cabinet that also fits my needs.
Date Posted: 29 May 2016 at 9:54pm
That's pretty much it, there's lots of info in the help section once you've downloaded it.
