Port depth question
Category: Plans
Forum Name: Ported Enclosures
Forum Description: Post all your reflex and bandpass and 'other' boxes with holes in stuff here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=96051
Printed Date: 27 March 2026 at 8:24am
Topic: Port depth question
Posted By: Pbg
Subject: Port depth question
Date Posted: 21 June 2016 at 1:53pm
I'm building some boxes for a space constrained use, so it's not as big as I'd prefer. As constructed, they tune slightly higher than intended (mid 30's), but I'm curious if there is any inherent issue with having a rather deep rectangular shelf port. Box is a bit over 200L, port is about 425 cm and 45cm deep. Thoughts appreciated.
Posted By: Crashpc
Date Posted: 24 June 2016 at 8:33pm
There is no issue with port 45cm deep once it is built properly and cross-section area is good for the application.
