Which cab formy beyma 12mi100's?
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=96554
Printed Date: 23 April 2024 at 12:45pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Which cab formy beyma 12mi100's?
Posted By: JBK
Subject: Which cab formy beyma 12mi100's?
Date Posted: 02 September 2016 at 6:40pm
Greetings fellow audio nerds,
As some may have seen in the scoop pr0n section ( http://forum.speakerplans.com/scoop-porn-part-2_topic46967_page219.html" rel="nofollow - http://forum.speakerplans.com/scoop-porn-part-2_topic46967_page219.html ) , our soundsystem have a mid section of 4 x 12" drivers running the 250-1400Hz frequency band in a closed enclosure (2x12" per box, no angle at all) They're Beyma 12mi100 drivers powered by a crest cc4000(2 a side , rated 1350W/channel @ 4ohm)
Until this summer everything where fine, but we have increased the system subs (scoops) and tops (horn & tweets) bud not the mediums, and we found that when playing at full volume drowned in the crowd the sound was fine except the mediums, they clearly lacked volume (i'd say definition but maybe the issue was only volume) I think the amp is not the issue.
I plan to lower the frequency cutoff to lower the 12" to cut them at 180ish (we got g subsunder) I would like to add an angle between drivers so the 12" wouldn't overlap, to cause less phasing issues, the problem is i can't find any info on dispertion vs frequency on these drivers. Also, I'm thinking of adding a horn to gain some db, to save the cost of adding cabs.
On the web I found people saying those drivers are OK in a mt122 mt121 or mt130, or even altec m17, but not frequency plots etc, neither simulated or recorded. I was thinking of building just the 12" part of those cabs, so I have a horn and angle. However, I'm a bit suspicious because the plans are not intended for those drivers I tried to sim one of those cab on hornresp to see what design would sound best, (even if it's not a guarantee of in real life success). but i think i need some more experience because after some time I felt like hitting my computer.
So my questions to your ladies and sirs are : - Do you have experience with this driver and can recommand an angle, or even better a plan for the frequency band I intend to use them? -Do you think I need not only to add an angle and a horn but also more cabs? (or just put an angle and see if i need more cabs) - Am I doing this completly wrong? - Am I over thinking this?
I really want to the take time to find the best option I'm not in a hurry, to my ears our sound sounds sweet and stillloud when it's not pushed too hard but at the festival we played at, they're was a serious crowd screaming etc (check the video in the link before to see what i mean) but on normal duties I think we come close to what we wanted (well I'm not 100% satisfied on the low medium also but each thing in its time)
Posted By: JBK
Date Posted: 06 September 2016 at 8:53am
Come on guys, don't let me slip to 2nd page :'( Nobody has experience with 12mi100? Advised enclosures At least hints on how i can estimate best angle? Thanks
Posted By: bob4
Date Posted: 06 September 2016 at 12:46pm
JBK wrote:
mid section of 4 x 12" drivers running the 250-1400Hz frequency band in a closed enclosure (2x12" per box, no angle at all) Beyma 12mi100 drivers powered by a crest cc4000(2 a side , rated 1350W/channel @ 4ohm)
JBK wrote:
I would like to add an angle between drivers so the 12" wouldn't overlap, to cause less phasing issues, |
"phasing issues" doesn't seem like a proper term for me (I might be wrong). What do you mean with this?
Also, what is the reason you want to do this? Is there a real problem in the mids that you can hear? If you have the time, listen to only your mid box, and move in front of it to see if the sound is bad or changes a lot while you move. If it doesn't, there is probably no problem.
For most of the frequency band you are using the 12"s in (up to maybe ~1 kHz) that shouldn't be a problem. They should sum just fine. Comb filtering starts when the drivers play back frequencies with wavelengths shorter than the distance between each other. In your case there might be a little bit of comb filtering in the upper end of your mids since you are running frequencies which have smaller wavelength than driver diameter (30 cm). If your HF driver/horn combination is strong enough, you could try lowering your crossover point towards 1 kHz.
If you look at the picture that I posted in the scoop porn thread around the same time as you, you can see the mid section of Ivah sound. It consists of four single 12" horn sections of mt122 (IIRC!) loaded with Fane 12" (IIRC!). It is operated 200 Hz - 1kHz with a little boost between 500 and 1000 Hz.
I can't comment on the suitability of your driver (I'm sure there are other members who can), but I think 200 Hz to 1 kHz is doable with a decent 12". Not too much low frequencies, but also not too high to have problems or need a phase plug.
JBK wrote:
I plan to lower the frequency cutoff to lower the 12" to cut them at 180ish (we got g subsunder) |
why? Gsub doesn't go high enough? 15" design might be better (also less heavy ) for this purpose
Posted By: bob4
Date Posted: 06 September 2016 at 1:30pm
I simulated two 12MI100 in closed box in Winisd.
on paper 12MI100 seems quite a good choice. It has good sensitivity and high BL. But xmax is not very high, so for direct radiating you can't expect too much bass.
According to my simulation for closed box, above 200 Hz enclosure size doesn't matter too much. Excursion stays mostly below xmax regardless of enclosure size. So without knowing your exact enclosure I can say that if you cross over at 250 Hz, you can give your drivers full power without a problem, and reach 130 dB with a pair of 12MI100.
But dropping crossover frequency below 200 Hz will very likely get you into trouble. You will exceed xmax and get distortion! Maybe even damage your driver.
The datasheet also has a power compression chart, according which you might get up to 4 dB of power compression at full power. So there is a limit to what you can get out of these guys in closed box.
https://www.beyma.com/getpdf.php?pid=12MI100" rel="nofollow - https://www.beyma.com/getpdf.php?pid=12MI100
Posted By: JBK
Date Posted: 06 September 2016 at 1:40pm
Well thanks for taking the time !
bob4 wrote:
"phasing issues" doesn't seem like a proper term for me (I might be wrong). What do you mean with this?Also,
Well I noticed, when turning on the amps whil signal was in, that I heard a different "tone" when playing the 2 box together vs just one box playing. I mean, instead of beeing a bit louder when powering the 2nd box, it also change a bit the "tone" the "sound" of the music playing through, that's what I thought about phase issue. Sorry I'm no pro in audio and I'm a french guy so maybe I do not chose the right words. But to my (quite inexperienced) ears it sounded like comb filtering, which (I've read, been told, and a bit understood) is due to the driver aiming a bit at each other, resulting in some frequency adding and another frequency substracting in one point. Might be wrong I did not made the test you mention, will do that next time we stack the sound. When I say 1400Hz, in fact each time we stack the system I set the crossover frequency by ears, most of the time it's between 1.2k and 1.6k. I'll try to lower that
between 500 and 1000 Hz |
Exactly the kind of box I was thinking about
bob4 wrote:
why? Gsub doesn't go high enough? |
Well it is an asumption, real world will confirm, but letting just the g subs play I hear some lower frequencies of the voice or instrument and i does not sound ultra sweet ...
bob4 wrote:
5" design might be better (also less heavy ) for this purpose |
Yes I know now, but I wasn't in the crew and hasn't that knowledge when the sound was first built ;) so for now we stick to the g subs that still do the work.
Maybe just the core of problem is that we don't have enough speakers ....
Posted By: Earplug
Date Posted: 06 September 2016 at 2:24pm
A quick search threw up this:
http://www.dancetech.com/index.cfm?loading=pa&pa_loader=175" rel="nofollow - http://www.dancetech.com/index.cfm?loading=pa&pa_loader=175
Note what it says there: "These again are short-throw cabs", so I´d say that you´d definitely be better off making some horn-loaded cabs, like the MT122.
------------- Earplugs Are For Wimps!
Posted By: bob4
Date Posted: 06 September 2016 at 2:33pm
most of the dancetech designs don't strike me as being very refined. Seems more the kind of "build dis kinda box, throw in whatever driverz yu have, it will make some noizz (proceed to drink beer)"
Posted By: JBK
Date Posted: 06 September 2016 at 2:52pm
Thanks earplug but as bob4 stated I'm not fond of throwing any driver in a random enclosure ... Hence why I come searching for someone with real world experience with them drivers.
Also, if i made two or three of them boxes stacked side by side, some drivers would aim directly at each other? this doesn't feel right...
Again I mentionned mt122 130 121TDA etc but they're not made for this driver. We can't afford building boxes and then see if it's good, I'd hope someone would've made the test and give their experience.
Posted By: bob4
Date Posted: 06 September 2016 at 3:03pm
@JBK:
1. do you use speaker management/DSP? 2. do you know how to use winisd?
looking again at the pictures of your stack (looks nice btw ) I see the mid boxes have a big distance between the individual 12" drivers. This is the reason why you hear this "phasing", and it is the first thing you may want to change. The drivers will couple much better if they are right next to each other (like the bullet tweeters in your array). Maybe you could build one smaller box with tighter spacing to try it. That should decrease the "phasing" sound you described significantly.
I estimate that your current mid box has an internal volume between 80 - 100 litres.
According to winisd, closed box will have very similar frequency response for a wide range of box sizes. Basically it doesn't matter if the box is 20 or 100 litres. The only difference will be that cone excursion is limited more by small enclosures.
here is a link to an old but very useful book written by bob mccarthy. There is a lot of useful information in it. Although it refers a lot to Meyer Sound products, it contains a lot of useful acoustics, electroacoustics and system design knowledge: http://197.14.51.10:81/pmb/TELECOMMUNICATION/Meyer_Sound_Design_Reference_for_by_Bob_McCarthy_Sound_Reinforcement.pdf%20" rel="nofollow - http://197.14.51.10:81/pmb/TELECOMMUNICATION/Meyer_Sound_Design_Reference_for_by_Bob_McCarthy_Sound_Reinforcement.pdf
Posted By: JBK
Date Posted: 06 September 2016 at 3:30pm
1. do you use speaker management/DSP? No we use the 4way crossover from the preamp (dubsonic) and filter the mid section for the 12"/compression drivers (hence why I can change this cutoff frequency but not the others) I'm actively trying to convince the rest of my mates that a lms would actually be a good idea, I think I will end buying a berry ultradrive on my own and not let them the choice (I'm the youngest and last arrived in the crew but the most curious technically I always try to improve things and I'm never 100% satisfied, but it's hard to convince others to start building again and spending €€€ on gear because "it already works fine" if you know what i mean )
2. do you know how to use winisd? No but I'm curious about it so I can try ( For what it's worth I'm a software engineer so I'm not afraid of softwares ;) ) However I tried to sim one of the horn cab in hornresp and it was a pain in the a.s.s however I think I need more than a few hours to fully understand the soft.
Thanks for taking the time :)
bob4 wrote:
looks nice btw |
thanks, it sounds pretty sweet also
Posted By: bob4
Date Posted: 06 September 2016 at 3:48pm
don't worry, winisd is quite easy. The only bad thing about it is that you have to constantly switch the graph between different parameters.
Happy to help :)
Posted By: APW
Date Posted: 06 September 2016 at 4:14pm
bob4 wrote:
most of the dancetech designs don't strike me as being very refined. |
That’s because a lot of them are copied straight from the old fane constructors handbook, however dancetech are missing the driver details and frequency plots that are in the book, the angled box in the dancetech link was on page 44 of the book, the frequency plot in the book for the cab is dated 23rd March 83, so the design is at least 33years old!!
Posted By: concept-10
Date Posted: 06 September 2016 at 4:50pm
bob4 wrote:
most of the dancetech designs don't strike me as being very refined. Seems more the kind of "build dis kinda box, throw in whatever driverz yu have, it will make some noizz (proceed to drink beer)" |
perfect 😊
Posted By: bob4
Date Posted: 06 September 2016 at 7:41pm
I swear, speakerplans forum is like an addiction.......
Posted By: Earplug
Date Posted: 06 September 2016 at 7:47pm
Yes, those cabs would need to be stacked on top of each other, or a large gap left between them.
I just did a quick search and found these:
http://www.ebay.co.uk/itm/Martin-Audio-MH212-Philishave-Midrange-pair-of-cabs-with-RCF-L12P24-/361697546269?hash=item5436da901d:g:PPQAAOSw65FXudgm" rel="nofollow - http://www.ebay.co.uk/itm/Martin-Audio-MH212-Philishave-Midrange-pair-of-cabs-with-RCF-L12P24-/361697546269?hash=item5436da901d:g:PPQAAOSw65FXudgm
One of the best mid-cabs ever made. So you could just sell your Beyma´s and buy those!
Posted By: bob4
Date Posted: 06 September 2016 at 8:50pm
ok, so I remembered that there is some info on this subject in the speakerplans faq:
http://speakerplans.com/index.php?id=faq10" rel="nofollow - http://speakerplans.com/index.php?id=faq10
The best drivers for mid horns have a high Fs (resonance) and a low Qts.
A high BL factor is also important. Basically this means that you want a
driver that has a stiff suspension, is well damped and has a strong
motor. A "tight" driver some would say. You can do a quick sum to see if
a driver is suitable for horn use. Take the Fs, divide [...] by the Qes. This is called the drivers
efficiency bandwidth product, for 12" drivers and smaller for use in
horns a figure above 180 is good. Figures above 200, like with the PD
122 are very good and should work well in horns. |
Beyma 12MI100 : EBP = 58/0,23 = 253 BL =21,6 -> should be useable!
now we just need someone who can do a hornresp sim of it in a suitable DIY horn, like mt122
Posted By: fatfreddiescat
Date Posted: 06 September 2016 at 9:44pm
+1 effin loud as well
Posted By: JBK
Date Posted: 07 September 2016 at 9:30am
Well thanks guys for taking the time, speakerplans is an addiction indeed !
I saw that http://dubsounds.free.fr/dubforum/viewtopic.php?f=15&t=3669" rel="nofollow - http://dubsounds.free.fr/dubforum/viewtopic.php?f=15&t=3669
The guy (blackboard jungle soundman) is still making those, they're designed for the 12mi100 (that's the driver they are using in), When selling the horns they give the dimensions of trapezoidal boxes suited for those horns.
Given the fact that we're no pro builders nor designers I think this would be an easy solution (just build a trapezoid box, no funny horn business with angles everywhere). Also I've heard BBJ and while it's not my favorite sound in terms of quality and clarity they do the job! If i get the time and patience I'll try to sim the drivers in a mt122. Maybe not a cheap solution but easy.
As for the martin audio, thanks but I won't buy something I've never heard :/ also check our sound we want to build boxes with the same wood so that it stays coherent visually.
Posted By: Earplug
Date Posted: 07 September 2016 at 10:25am
"As for the martin audio, thanks but I won't buy something I've never heard"
Ok, fair enough - but I´d say that anything made by Martin is going to be pretty good/better than some DIY horns, especially the Philies that definitely have stood the test of time...
Also I note that you don´t have any processor. So how do you hope to align any horn cab you buy or build to the other speakers in your stack? That´s just asking for more problems. So unless you do take the plunge and invest in a DSP, you may be better off just sticking with simple front-loaded cabs.
Posted By: JBK
Date Posted: 07 September 2016 at 10:38am
Yes I intend to buy a processor if it's the case.
Posted By: bob4
Date Posted: 07 September 2016 at 7:57pm
Did you see these comments?
bob4 wrote:
According to my simulation for closed box, above 200 Hz http://cesco.com/b2c/product/59291" rel="nofollow - enclosure size doesn't matter too much. Excursion stays mostly below xmax regardless of http://cesco.com/b2c/product/59291" rel="nofollow - enclosure size .
But
driver.
https://www.beyma.com/getpdf.php?pid=12MI100" rel="nofollow - https://www.beyma.com/getpdf.php?pid=12MI100 |
significantly.
According
more by small enclosures. |
Posted By: JBK
Date Posted: 08 September 2016 at 11:42am
Yes thanks for those insights. The fact is that with a horn I expect to gain a few db , and directivity. as i doubt my cp380 can go down to 1000Hz
So now I saw those moulded horns on redlion and they were made for the beyma 12mi100, so it seemed a good solution, not financially but the most simple technically ( no need to sim anything, it's real world proven combination) in order to gain db (with horn) and directivity (over 1000Hz with an angle)
Maybe your solution is the simplest in order to get rid of the phase issues but I'm affraid it would still lack directivity (which is not the major issue btw) over 1000Hz, and maybe it would still lack some volume compared to the other bands, but we could just build one more box and buy 2 more hps to compensate)
Posted By: bob4
Date Posted: 09 September 2016 at 10:06am
http://https://www.beyma.com/products/compressiondrivers/1CP380M8" rel="nofollow - http://https://www.beyma.com/products/compressiondrivers/1CP380M8
according to datasheet power rating is 70W AES above 1,5 kHz, the second rating is probably thermal maximum.
1,2 kHz is recommended as lowest crossover frequency.
107 dB sensitivity on a horn -> ~125 dB SPL with 64 W input, +6 dB for using four horns -> ~131 dB total. Maybe 3 dB more for peaks.
according to winisd, one of your mid boxes should be able to take full power (800-900W) and deliver around 130 dB. So in theory one of your mid boxes should be able to keep up with all four HF horns. The second box provides a little bit more headroom....
