Poorly Yamaha REV500
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=96650
Printed Date: 26 March 2026 at 5:30pm
Topic: Poorly Yamaha REV500
Posted By: Jimmer
Subject: Poorly Yamaha REV500
Date Posted: 12 September 2016 at 9:17pm
Evening Chaps!
I have a Yamaha Rev500 that's taken a whack to the input potentiometer. Needs a new one as its completely obliterated!
I have sourced the service document and it is a Panasonic EVJC20 10Kohm 2gang, which of course is now discontinued and not in stock with farnell. Cry (never easy is it!!)
So my question is do any of you fine gentlemen have any knocking around the shed, or can anyone recommend a suitable replacement?
Thanks in advance!
Jimmer
http://connect-av.co.uk" rel="nofollow - http://connect-av.co.uk
Posted By: Jimmer
Date Posted: 14 October 2016 at 1:41pm
Anyone able to help? before i solder two resistors in its place!
Posted By: odc04r
Date Posted: 14 October 2016 at 2:08pm
Do you know the full device number? From a quick browse it looks like it might be a 14mm wide pot? If so Alps have a 14mm range too which look fairly similar in pinout (a lot of pots do have similar footprints).
Is it a dual log 10k pot? If so a part that might do is RK14K12A0A3C (no bushing) or RK14K12B0A0E (with bushing).
Posted By: Jimmer
Date Posted: 14 October 2016 at 2:29pm
Top man, on a quick look they look promising Thumbs Up Just popping out but will double check later and see if they'll do the trick....cheers Bud
Posted By: CASTANEDA
Date Posted: 30 January 2025 at 1:25am
Hi mate!
I have exactly the same problem (my REV500 hit the floor during a bump in at the Australian Hotel, Wingham) and the input pot is terminally smashed.
Were you able to source a replacement EVJC20 10Kohm 2gang or did you end up wiring in a pair of 5ks instead? The Alpine equivalent pot is proving tricky to source!
Cheers - Dean
