Electric-Arc Loudspeaker - The innovative solution
URL: https://forum.speakerplans.com/forum_posts.asp?TID=96952
Printed Date: 26 March 2026 at 4:57pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Electric-Arc Loudspeaker - The innovative solution
Posted By: What is it
Subject: Electric-Arc Loudspeaker - The innovative solution
Date Posted: 26 October 2016 at 12:04am
What do
you think about this?
Information and video
link:
http://vigeraudio.livejournal.com/ - http://vigeraudio.livejournal.com/
Posted By: MattStolton
Date Posted: 26 October 2016 at 8:29am
Two issues:
1) Only really any good outdoors - excessive ozone in the home is not that great an idea.
2) Low sensitivity means that for pro-audio use, outdoors, 113dB max isn't loud enough.
The only thing going for it, is the beautiful waterfall plots, no overshoot at all - wonderful. But apart from that, can't see the benefit, too many drawbacks.
Perhaps play music at penguins, to keep them happy, and fill the ozone hole at the same time?
------------- Matt Stolton - Technical Director (!!!) - http://www.wildingsound.co.uk" rel="nofollow - Wilding Sound Ltd "Sparkius metiretur vestra" - "Meter Your Mains"
Date Posted: 26 October 2016 at 9:33am
Penguins.
Also watched the video, (the girl has a lovely voice by the way,is she single? ) interesting,but seems an excessively complicated answer to a problem that doesn't really exist? Probably also bibically expensive,and very power inefficient? Every transducer will need its own mains supply?
------------- Be seeing you.
Date Posted: 26 October 2016 at 9:58am
jbl_man wrote:
Every transducer will need its own mains supply? |
That isn't a deal breaker, quiescent is 35W, peak power of 80W, so not too weird in the greater scheme of things. Universal SMPS so easy to just plug into local supply, whatever voltage.
My issues, are with emissions of all types. Ozone in a domestic environment, is not pleasent, just ask an asthmatic. Equally, the audio emissions, whilst looking to be free of any distortion from diaphragm overshoot (the waterfall looks awesome), is just not efficient enough.
If I am being really picky, looks to only really do 4K-15K +-3dB. Decent ribbon will exceed that, and offer similar waterfall, with often higher sensitivity (alcons stuff will rip your ears off with SPL), but no nasties. Even Peavey managed to make a ribbon for PA use.
I have seen home brew versions of these on the net, and whilst impressed with the ingenuity to make it work, the compromises are too high.
Date Posted: 26 October 2016 at 2:53pm
About OZONE ... Read chemical encyclopedia, basic
literacy. Ozone at temperatures above 158F breaks, cold plasma is very
difficult to obtain for ozone. For use powerful arc lamps (efficiency = 1%),
where a lot of ultraviolet light, and it adds an oxygen atom. very not for
long!
Information about the absence of mechanical parts, to overload as much
as you do not break in touring work is important. Ribbon afraid overload and
expensive + amp? Price?
I think the sound of EAL much better than any of-Ribbon. Type PRO work
in a group, pick up the required number and receive power in high fidelity
sound.
While for outdoor can not come, only inside
buildings.
Date Posted: 26 October 2016 at 3:07pm
literacy. Ozone at temperatures above 158F breaks...
Exactly.
When it breaks down it generates a molecule of O2, and an Oxygen free radical. Free radicals are the danger....
At sea level, even at concentrations of around 0.01ppm, detectable to human nose, and considered unpleasent, and causes major respiratory issues for vulnerable parties.
About MattStolton ... BSC (Hons) Chemistry, 2II (Desmond!) - Queen Mary & Westfield, Class of 97.
Feel free to shoot me down about the dangers of Ozone in a domestic setting.
Date Posted: 26 October 2016 at 6:42pm
A few seconds on the wonderful webthingy gives you this - peer reviewed overview:
https://www.epa.gov/sites/production/files/2014-08/documents/residential_air_cleaning_devices.pdf" rel="nofollow - https://www.epa.gov/sites/production/files/2014-08/documents/residential_air_cleaning_devices.pdf
Author: U.S. Environmental Protection Agency - Office of Air and Radiation; Indoor Environments Division, 1200 Pennsylvania Avenue, NW
Mail code: 6609J
Washington, DC 20460
http://www.epa.gov/iaq " rel="nofollow - www.epa.gov/iaq  ;
Pages 21-22
"Ozone Generators:
Ozone generators sold as air cleaners and marketed
as in-duct or portable units use UV light or corona
discharge to produce ozone, which is dispersed by a
fan into occupied spaces.8
Some manufacturers and vendors of ozone
generators suggest that ozone reacts with both
chemical and biological pollutants and transforms
them into harmless substances. They also often
make statements and distribute materials that
lead the public to believe that these devices are
always safe and effective in controlling indoor air
pollutants. However, ozone is an irritant gas that
reacts with lung tissue and can cause asthma attacks;
coughing; chest discomfort; irritation of the nose,
throat, and trachea; and other adverse health effects.
Ozone is a lung
irritant that can
cause adverse health
effects.
As ozone reacts with chemical pollutants, it can
produce harmful by-products.8, 9, 10
Available scientific evidence shows that, at ozone
concentrations below public health standards,
ozone has little potential to remove indoor
air contaminants such as many odor-causing
chemicals, viruses, bacteria, molds, and tobacco
smoke; thus, ozone is generally ineffective in
controlling indoor air pollution.
Some controlled
studies show that the concentration of ozone
produced by ozone generators can exceed
standards even when consumers follow the
manufacturer’s instructions. No federal agency
has approved ozone generators for use in occupied
spaces.
There is a large body of written material
on ozone and the use of ozone indoors, but
much of this material makes claims or draws
conclusions without substantiation and a basis in
sound science.
In developing Ozone Generators
that Are Sold as Air Cleaners, EPA reviewed a
wide assortment of this literature, including
information provided by a leading manufacturer
of ozone-generating devices. In keeping with
EPA’s policy of ensuring that the information
it provides is based on sound science, only peer
reviewed, scientifically supported findings and
conclusions were relied on in developing this
document. The document is posted on the EPA
Web site at http://www.epa.gov/iaq/pubs/ozonegen.html.%20" rel="nofollow - www.epa.gov/iaq/pubs/ozonegen.html.
The public is advised to use methods proven to
be safe and effective in controlling indoor air
pollution. These methods include eliminating
or controlling pollutant sources and increasing
outdoor air ventilation.
Federal pesticide law requires manufacturers of
ozone generators to list an EPA establishment
number on the product’s packaging. This number
merely identifies the facility that manufactured
the product. The presence of this number on a
product’s packaging does not imply that EPA
endorses the product, nor does it imply that EPA
has found the product to be safe or effective."
Cited references: 8. Ozone Generators that are sold as air
cleaners: An assessment of effectiveness
and health consequences. U.S.
Environmental Protection Agency.
http://www.epa.gov/iaq/pubs/%20" rel="nofollow - http://www.epa.gov/iaq/pubs/
ozonegen.html
9. Shaughnessy, R.J., and Sextro, R.G.
2006. What Is an Effective Portable
Air-Cleaning Device? A Review. Journal
of Occupational and Environmental
Hygiene. Vol. 3, pp. 169-181.
10. Weshler, C. J. 2006. Ozone’s Impact
on Public Health: Contributions
from Indoor Exposures to Ozone and
Products of Ozone-Initiated Chemistry.
Environmental Health Perspectives. Vol.
114, No 10, pp. 1489-1496.
When the EPA come out and say "Ozone is bad", it really must be bad, given all the things they are accused of rubber stamping as acceptable!!
The original cited EPA document (8) is missing, but found an excerpt which is relevant:
http://www.allergyclean.com/problems-with-ozone-generators-and-ionizers-that-produce-ozone/" rel="nofollow - http://www.allergyclean.com/problems-with-ozone-generators-and-ionizers-that-produce-ozone/
From the document http://www.epa.gov/iaq/pubs/ozonegen.html" rel="nofollow - www.epa.gov/iaq/pubs/ozonegen.html
"What is ozone?Ozone is a molecule composed of three atoms of oxygen. Two atoms of oxygen form the basic oxygen molecule — the oxygen we breathe that is essential to life. The third oxygen atom can detach from the ozone molecule, and re-attach to molecules of other substances, thereby altering their chemical composition. It is this ability to react with other substances that forms the basis of manufacturers’ claims. How is ozone harmful?The same properties that allow high concentrations of ozone to react with organic matter outside the body give it the ability to react with similar organic matter that makes up the body, and potentially cause harmful health consequences. When inhaled, ozone can damage the lungs. Relatively low amounts can cause chest pain, coughing, shortness of breath and throat irritation. Ozone may also worsen chronic respiratory diseases such as asthma and compromise the ability of the body to fight respiratory infections. People vary widely in their susceptibility to ozone. Healthy people, as well as those with respiratory difficulty can experience breathing problems with exposure to ozone. Exercise during exposure to ozone causes a greater amount of ozone to be inhaled, and increases the risk of harmful respiratory effects. Recovery from the harmful effects can occur following short-term exposure to low levels of ozone, but health effects may become more damaging and recovery less certain at higher levels or from longer exposures (US EPA, 1996a, 1996b). Are ozone generators effective at controlling indoor air pollution?Available scientific evidence shows that at concentrations that do not exceed public health standards, ozone has little potential to remove indoor contaminants. First, a review of scientific research shows that for many of the chemicals found in indoor environments the reaction process with ozone may take months or years (Boeniger, 1995). Second, for many chemicals with which ozone does readily react, the reaction can form a variety of harmful or irritating by-products (Weschler et al., 1992a,1992b,1996; Zhang and Lioy, 1994). Machines that generate ozone are not effective in removing carbon monoxide (Salls, 1927; Shaughnessy et al., 1994) or formaldehyde (Esswein and Boeniger, 1994). In fact, when tested on new carpet odors and gasses, the reaction with ozone actually increased the number of aldehydes and volatile organic compounds (Weschler et al., 1992). Some of these new compounds created through the reaction with ozone are very reactive, irritating and a potential health threat. Third, ozone does not remove particles (e.g., dust and pollen) from the air, including the particles that cause most allergies. However, some machines that generate ozone also produce ions. An ionizer is a device that disperses negatively (and/or positively) charged ions into the air. These ions attach to particles in the air giving them a negative or positive charge so that the particles may attach to nearby surfaces such as walls, furniture or each other and settle out of the air. Some units also have internal “plates” that help gather particles. In recent experiments, ionizers were found to be less effective in removing particles of dust, tobacco smoke, pollen or mold spores than either HEPA filters or electrostatic precipitators. (Shaughnessy et. al, 1994) If a machine does not emit more than 50 parts per billion allowed by the EPA, can it still be harmful?Yes, there is no “safe” level of ozone. For many people, even at the 50 parts per billion of ozone allowed by the EPA, exposure far exceeds the tolerance level. However, there are also other factors that contribute to ozone levels. First is the size of the room where the machine generating ozone is being used. In one study a machine run in a 350 square foot room generated ozone counts in the room of 500 to 800 parts per billion — ten times the allowable limit. Second, indoor air generally contains some ozone — particularly when ozone is at high levels in the outdoor environment. Indoor ozone concentrations generally run at 10 to 20 parts per billion, but can be as high as 30 to 50 parts per billion. When you add the ozone coming from a machine, it would most certainly exceed allowable limits. Third, the simultaneous use of multiple devices greatly increases the total ozone output and therefore greatly increases the risk of excessive exposure. The US Food and Drug Administration also addresses the issue of the labeling of machines that generate ozone. In the Code of Federal Regulations, Title 21, Volume 8, Part 801 ( http://www.fda.gov" rel="nofollow - www.fda.gov ) it states:“A number of devices currently on the market generate ozone by design or as a byproduct. Since exposure to ozone above a certain concentration can be injurious to health, any such device will be considered adulterated and/or misbranded within the meaning of sections 501 and 502 of the act if it is used or intended for use under the following conditions: - In such a manner that it generates ozone at a level in excess of 50 parts per billion by volume of air circulating through the device or causes an accumulation of ozone in excess of 50 parts per billion by volume of air in the atmosphere of enclosed space intended to be occupied by people for extended periods of time, e.g., houses, apartments, hospitals and offices. This applies to any such device, whether portable or permanent or part of any system, which generates ozone by design or as an inadvertent or incidental product.
- To generate ozone and release it into the atmosphere in hospitals or other establishments occupied by the ill or infirm.
- To generate ozone and release it into the atmosphere and does not indicate in its labeling the maximum acceptable concentration of ozone which may be generated as established herein and the smallest area in which such a device can be used so as not to produce an ozone accumulation in excess of 50 parts per billion.
- In any medical condition for which there is no proof of safety and effectiveness.
- To generate ozone at a level less than 50 parts per billion by volume of air circulating through the device and it is labeled for use as a germicide or deodorizer.” (Revised as of April 1, 2003)
Conclusions- Whether in its pure form or mixed with other chemicals, ozone can be harmful to health. When inhaled, ozone can damage the lungs. Relatively low amounts of ozone can cause chest pain, coughing, shortness of breath and lung irritation. Animal studies suggest that long term exposure to ozone may lead to permanent scarring of lung tissue, loss of lung function and reduced lung elasticity. It may also worsen chronic respiratory diseases such as asthma and COPD. Machines that generate ozone should never be used around the ill, infirm, young or elderly.
- Many factors affect ozone concentrations produced by machines that generate ozone including the amount of ozone produced by the machine(s), the size of the indoor space, the amount of material in the room with which ozone reacts, the outdoor ozone concentration and the amount of ventilation. These factors make it difficult to control ozone concentrations.
- Available scientific evidence shows that, at concentrations that do not exceed public health standards, ozone is generally ineffective at controlling indoor air pollution. In the process of reacting with chemicals indoors, ozone can produce other chemicals that themselves can be irritating and corrosive."
So. 50 parts per billion is mentioned as being a safe lower limit, but even then, can cause injury to individuals with sensitivity. Basically, no safe lower limit.
And you want to put 2 devices, within a few metres of a human, breathing away, listening to their Steely Dan LP for an hour or two.
You must be able to see the possible problem?
Date Posted: 27 October 2016 at 12:22pm
Traditional
ionophone and EAL are very different devices essentially. While using
a single energy transfer principle. No similar Electric-Arc
Loudspeakers device is not currently commercially produced, so compare them
with ionophone - incorrectly.
1. EAL is
not ozone generator. 2. The
device is not using corona discharge.
3.
Measurement of ozone at 1
meter does not exceed the background noise.
Valid
for corona discharge is needed, one electrode and the second electrode - the
environment. Therefore, approaching the second virtual electrode ionized gas
(plasma) cools forming O3 in small quantities, which decays in a few minutes.
The
EAL electric arc has no cold zones, as it has two electrodes, between which
closed the flow of electrons in the ionized gas and heated to the same
temperature, prevents the formation of O3. In addition, the air flow path of
the catalyst has Horn.
At
(70C),
ozone is formed.
P.S.
You,
and not only you, confuse the ionized air with ozonized
Why does everyone like the air after a
thunderstorm even asthmatics?
Because ozone in the air? .... Or
ions?
When
you fry something in the kitchen and the smell in the whole house ... ..
Are you sure that all this is good for
your health? ....
Posted By: odc04r
Date Posted: 27 October 2016 at 12:27pm
How much they paying you to try and sell this stuff then? 4 posts, all one topic.
I'd prefer ionized air to air with oxygen radicals in it, ions have a much shorter mean lifetime.
Every ozone generator I have ever used has been done so under interlocks and extract. Atomic layer deposition tools, ozone generators for surface cleaning. Indoor use admittedly. Manufacturers would not waste the money or insist upon the facilities if it wasn't a good idea.
Anyway I agree with Matt, interesting idea but too much complication with little improvement upon the existing methods of reproduction to get significant uptake.
