ES 18 BPH in Hornresp
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=97187
Printed Date: 27 March 2026 at 9:30am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: ES 18 BPH in Hornresp
Posted By: Marko
Subject: ES 18 BPH in Hornresp
Date Posted: 25 November 2016 at 8:08pm
Please someone take a look at this and help me.
Black is Faital 18HP1060 grey is B&C 18 TBX 100 in simulation of ES 18 BPH.
 What I'm doing wrong here? These are the parameters of 18 HP1060 driver and ES 18 BPH box.
Posted By: corell
Date Posted: 25 November 2016 at 9:01pm
What your doing wrong is loading a "kick cab" with dedicated subwoofer chassis. The plot is right! Try something with a lighter cone like the B&C 18PZB100 or similar. this will make things better, but not perfect. Bandpasshorns just dont perform on their own... What are you using below them? As you can clearly see, you will need something below!
Posted By: Marko
Date Posted: 25 November 2016 at 9:44pm
 Now, black is 18PZB100 grey is 18HP1060. Peak at 80 Hz and f3 at 64 Hz?? I cant believe this is true for a cabinet this size?
Posted By: cravings
Date Posted: 25 November 2016 at 9:56pm
well it looks a bit better.. have you tried fane 18sb, or precision devices pd188?
Posted By: Marko
Date Posted: 25 November 2016 at 10:20pm
Black Fane 18SB grey PD 188.
There must be something wrong with Hornresp parametars of the enclosure. Please can someone with Hornresp installed try to do a simulation. I would really appreciate that!
Posted By: MarjanM
Date Posted: 25 November 2016 at 11:14pm
Its all perfectly fine. It ks a kick bass, not a subwoofer.
------------- Marjan Milosevic MM-Acoustics www.mm-acoustics.com https://www.facebook.com/pages/MM-Acoustics/608901282527713
Posted By: Sypa
Date Posted: 26 November 2016 at 2:57am
From experience 6 es18s with tbx100 play sub on their own quite well
Posted By: bitSmasher
Date Posted: 26 November 2016 at 6:57am
Will these sit on the ground or above subs? If the latter, then set to 4pi
------------- https://www.instagram.com/batteryacidsoundsystem/
Date Posted: 26 November 2016 at 12:04pm
Don't look at a plot of a single F218
