Cerwin Vega B36
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=9757
Printed Date: 26 March 2026 at 11:31pm
Topic: Cerwin Vega B36
Posted By: d-link
Subject: Cerwin Vega B36
Date Posted: 01 May 2007 at 1:34am
hey guys, just wondering how wide the cerwin vega b36 is... found a couple of plans... suggesting it is front facing 24" wide and 36" tall is this correct ?
http://imageshack.us">
Posted By: Tony Wilkes
Date Posted: 01 May 2007 at 10:07am
Just scale it using one of the known dimensions as a ref.
Tony
Posted By: COWFOOT
Date Posted: 01 May 2007 at 1:24pm
Looks like the B36 would make a good kickbin.What's the frequency response like?
Posted By: d-link
Date Posted: 01 May 2007 at 1:34pm
www.cerwinvega.com
Performance Data
Frequency Response: 35 Hz - 300 Hz
Peak Power Handling: 1000 watts
Program Power Handling: 500 watts
Nominal Impedance: 8 Ohms
Sensitivity (1w/1m): 106 dB
Posted By: levyte357
Date Posted: 01 May 2007 at 3:03pm
Originally posted by COWFOOT COWFOOT wrote:
Looks like the B36 would make a good kickbin.What's the freequency response like?
The SP council have decided it's naughty using 18" loaded cabs as kick bins.
I hear the Vega SL-36/AB36(afterburner) are  the only ones worth building, but you only get down to 30hz with 8, OR, 4 corner loaded or something.
Anyone have/seen decent plans of these?
http://srforums.prosoundweb.com/index.php/m/3101/0
Thu, 13 May 2004 18:27 javascript://"> javascript://">
  http://srforums.prosoundweb.com/index.php/u/1565/0/ - Mr.Nightro
Has No Life
I was given a pair of Cerwin Vega SL-36 subs that where in great shape but where unloaded about three months back. The first thing I did was add additional bracing internally then sprayed the internal chamber with Road Kill sound dampening spray. The wiring & back plate where missing so I soldered some 12 guage wire onto the factory plates from some old CV cabs I had laying around, then I loaded them up with a pair of JBL 2241G 18" subwoofers rated at 600 watts RMS @ 4 ohms that where serving as oversized paper wieghts in my sound room. I used a pair of QSC MX1500a each bridged (1300 watt @ 4 ohms bridged) & powering one SL-36, I then used my DBX Driverack PA to high pass them @ 35hz & crossed over at 80hz then put a delay of 5.46ms to my tops as spec'd by the Cerwin Vega tech dept. I said all this to say that these cabs now deliver deep tight bass that thumps deep within your chest & rumbles in your gut, for tops I am using a pair of Electrovoice T252 on top & a pair of Electrovoice Eliminator i tops on stands & still have excessive bass while playing bass heavy bass. If you are using these in a small room you will not get the full effect & potential of these cabs & would be better off using these in a larger room or outdoors. Though I admit there are better cabs available out there these aren't all that bad once properly powered, processed & placed.
Date Posted: 01 May 2007 at 4:17pm
Vega SL36 plan.
EDIT:Just realised this is also on Staiper's msn site. Anyone made it yet ?
Posted By: d-link
Date Posted: 01 May 2007 at 8:15pm
right well i've knocked one up today and as u can see... sexy momma
still gotta do the braces, screw and glue to bring the joins together... as for that all done
Date Posted: 01 May 2007 at 8:29pm
Which one have you built mate ?
Also, do yourself a favour, brace the sh$t out of it, and deliberately make it heavy, with some double bracing.
Which driver have you got to test it with?
Posted By: d-link
Date Posted: 01 May 2007 at 9:27pm
JE-36B, shame it's the junior, but seeing as this was just a test build, i'm more than happy to build a few of the afterburners...
Date Posted: 01 May 2007 at 9:57pm
OK. Don't over do it on the junior then...
Just remember junior doesn't perform anywhere near full size.
Have'nt seen any plans for Afterburner (AB36), but "think"  its really just SL36/B36 with Alu front cover as heatsink, and better driver.
Lot's of people sl*g off CV  36 lines, cos they haven't heard it with decent driver, setup or placement. But CV did produce a lot of low build quality cabs, and  the junior is least performing.
However Afterburner is accepted as the best 36, and  people say their home builds with extra bracing, sound dampening and decent suitable drivers blast original cabs out the park.
Posted By: heinrich
Date Posted: 02 May 2007 at 4:38am
with a few mathematics..........
try to look at  this
http://img472.imageshack.us/my.php?image=cerwinvegaab36sm1.jpg
although needs to be corrected yet.............
I hope some one else have correct plans for this includung throat
dimensions..........
.....power is nothing without control....
Date Posted: 02 May 2007 at 9:24am
try to look at  this
This is basically the same cab as the sl36 plans (posted earlier in this thread), except the front chamber is metal and has 2 edges, not 1.
So if someone edits the sl36 plan, t plan and adds the brace missing from top of chamber, and alu cover dimensions, we have the AB-36 plans.
When that is done, I'm half tempted to scale up horn section (not chamber or throat) detail by 1.333, to get 9ft horn instead of standard 6ft, which would mean flat to 30hz, not 50hz.
Posted By: Mark James
Date Posted: 02 May 2007 at 10:09am
flat down to 30hz???
imo the best thing to do would be to use the vague plans available, and the age old horn responce doo dah, select an apropriate driver and "invent" the missing dimensions, ie redisign so it fits your aplication,
but to be honest all ive done is reworded your last sentence.......
you may just end up with a realy good cab though.... and its not technicaly a copy, youve just taken alot of inspiration and done a bit of work yourself......
insert silly sentence here
Date Posted: 02 May 2007 at 11:06am
Well, we now actually have all info required to fabricate an AB36. Have read many places 1850 loaded original AB36 will demolish 2x genuine AB36 no problem.
So after I have a cloned AB36 with suitable driver (1850 expensive and hard to get hold of), I'll take it from there.
For me the hardest part is translating hornresp figures to drawing's, not using hornresp or identifying good drivers. Have spent too much time recently doing exactly this.
Date Posted: 02 May 2007 at 6:11pm
yeah me too actualy........ hmmmmm if you think it would work then give it a whirl........ 30hz is a rather amusing thing at higher spl.........
Date Posted: 02 May 2007 at 7:43pm
Expanded official drawing of AB36
http://img46.imageshack.us/img46/2624/ab36rq3.jpg
Needs measurements detail from
http://groups.msn.com/_Secure/0SQAsD2IWZz%21OhXV7%21SEhLzaa7o856Z*RGRux9ejvJwxLZpzWj8M4UVe8Yqy7ldg5m9%212u%215aAtNIxcAdmtF06GRUmXCEkrPcWL%21rGkuWNSioArrr%21w5lnQ/l36.gif?dc=4675481959975824071 - http://groups.msn.com/_Secure/0SQAsD2IWZz!OhXV7!SEhLzaa7o856Z*RGRux9ejvJwxLZpzWj8M4UVe8Yqy7ldg5m9!2u!5aAtNIxcAdmtF06GRUmXCEkrPcWL!rGkuWNSioArrr!w5lnQ/l36.gif?dc=4675481959975824071
and front chamber measurements from here
I have'nt got decent graphic s/w on this PC to do the job, can someone else do this and put it up?
Regards.
Posted By: DJ Coupé
Date Posted: 02 May 2007 at 8:48pm
I have sl36 bins they are great. They seem to produce alot of bass
I run them from 30 - 80 some times 30 - 100
Posted By: heinrich
Date Posted: 03 May 2007 at 1:59am
actually I was planning to load this with SD18 p.audio but i think I will have problems fitting it inside since SD18's are deeper and larger in magnet size...
Date Posted: 03 May 2007 at 2:54am
Without even modelling this in hornresp, I cant tell the SD18 with 5mm Xmax aint it dawg.
This baby looks like it has fairly large chamber, which dictates something like PD1850/V18-1000, OR  18LW1400/RCFL18P300/PD186/18TBX100[.
Just found the following post which should help model SL36 and identify suitable drivers "properly".
WARNING:The below post and horn measurements are also for the JE36 (Junior),  which is only 24" (62.2 cm) Deep;  NOT the "Mighty" SL36.
http://www.speakerplans.com/forum/forum_posts.asp?TID=1314&KW=vega&PN=3 - http://www.speakerplans.com/forum/forum_posts.asp?TID=1314&KW=vega&PN=3
Posted By: heinrich
Date Posted: 05 May 2007 at 3:33am
well SD18 and C18 are the most available and reliable drivers that can be found here at home.....
I hope i could post some pictures of some crap type of speakers soon...
well they are marked 1000watt doubled magnet ones but when powered
with continues 800watt or so for some 4 hour or more , voice coils
deforms and burnt.......
Posted By: aperrado
Date Posted: 10 January 2008 at 7:02pm
hi i need info about cerwin vega eartquake b36 inc.plans measures very  important inside measures and details  any help will be appreciated  i saw some decent pics  but inside details is hard to find
Im hard to learn but still asking
Posted By: aperrado
Date Posted: 10 January 2008 at 7:18pm
can u post more pics about this work? it look good,  where u get plans or something to do it ? i want  try to make one
Posted By: aperrado
Date Posted: 10 January 2008 at 7:22pm
[QUOTE=d-link]right well i've knocked one up today and as u can see... sexy momma
can u put a complete pics of u work it look good  where do u get plans?
Posted By: aperrado
Date Posted: 11 January 2008 at 3:31am
do u still in this forum  i ask it bcs i need help on info about this sub  u know pics,tools,dimensions,tricks evrtingh
Posted By: aperrado
Date Posted: 13 January 2008 at 7:49am
ok do u have detail of this subs box?
Posted By: Hugo Biermann
Date Posted: 13 January 2008 at 9:59am
Look at this
Blue Line: SL-36 with SD18
Grey Line: 1850Horn with SD18
both modeled 1/8 space
img168/8291/compje9.jpg
AND the SD18 will just squeeze in.
img144/3865/slsd18zv9.jpg
Date Posted: 13 January 2008 at 10:24am
B36 loaded with P-Audio E18-600A.
Blue: 4 bins
Grey: single bin
img181/3796/b36uy5.jpg
Date Posted: 13 January 2008 at 5:19pm
And there's some more sh*t over here:
forum_posts.asp?TID=13805 - Some Bass Horns
