Peavey VSX26
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=97749
Printed Date: 26 March 2026 at 4:39pm
Topic: Peavey VSX26
Posted By: IainB
Subject: Peavey VSX26
Date Posted: 09 February 2017 at 9:00pm
Just out of interest, has anyone used a Peavey VSX26 before?
Picked one up recently to replace an Ecler FAP30 (because I just never learn) only to find out its not really supported be Peavey anymore.
Totally in at the deep end and wishing I had purchased a Behringer LMS instead, but thought I would ask on here first before pulling out what little remains of my hair
Posted By: bitSmasher
Date Posted: 10 February 2017 at 3:18am
Considered buying one whilst working for a Peavey wholesaler... but once I read about usability, even clearance prices couldn't convince me to buy one.
Fixed gains sounds like a headache, relying on amp attenuation to balance system
Posted By: IainB
Date Posted: 10 February 2017 at 1:58pm
That is a REAL PITA, on the upside im having to work things out myself, which will help me get a hang on setting everything up. Just hope I dont cook anything in the process.
Date Posted: 10 February 2017 at 3:06pm
The manual clearly shows that you can adjust the level of all the outputs?
Posted By: IainB
Date Posted: 10 February 2017 at 8:01pm
Totally agree, but Peavey in their wisdom only designed the VSX to be used with Peavey amps, Ive copied this from one of the postings on their site "All Peavey amplifiers have a fixed Voltage gain of Times Forty (X's 40) which is +32 dB of gain on the decibel scale". As I understand it, I need to go through all my amps and set the gain so that it matches the Peavey setting otherwise the internal processing all gets shot.
This is all very very new to me, but having known the 'quirks' I possibly wouldnt have bought it, I only checked the reviews, which were saying sound quality / processing is good.
Total newb Confused
Date Posted: 10 February 2017 at 11:28pm
Nope. +32dB is the most common amp gain in the touring world. If your amps have different gain then you just have to do the maths to set relative levels on outputs or do it by ear.
I don't know of any LMS that lets you input amp gain and adjusts the dB view to suit frankly, and if one did it would be more confusing.
Posted By: IainB
Date Posted: 19 March 2017 at 6:24pm
So enough reading and reading and confusing myself. Ive had a play around with the VSX am I right in my thinking (because the Peavey forum is like a ghost town)
Intending to use these as a stereo input and bi-amp (simple tops and subs to begin with)
Set Inputs and Outputs
Set crossover points 10-100 then 100-20000
Set limiter (need to calculate this still once Ive tested the amp output levels)
EQ at the venue using the inbuilt Autograph
Thats it isnt it? Its basic and Im not even scratching the surface, but its this or using my Ecler FAP30 and if I dont start using this, im never going too. Just dont want to fry my speakers but doing something wrong.
Next time... I will buy something that has a wider user base!
Posted By: Pinyorouk
Date Posted: 22 March 2017 at 2:37pm
I have set one of these up and was sucessfuly able to use the computer software. This was with a Peavey VSX system. Verified all limiter settings with the aid of a multimeter on each amplifier output. It was spot on using Peavey amps with fixed gain. Only thing I didn't like about it was not being able to set a password to lock editing within the unit.
Posted By: IainB
Date Posted: 22 March 2017 at 7:07pm
I dont suppose you still have a copy of the VSX software? Peavey have removed it from the download section Cry
Am I correct in my plan of action about how to configure it, I know what Ive written is really simple, just want to make sure im in the ballpark, first gig using the VSX is in just over a week Censored
Posted By: ewan360
Date Posted: 23 March 2017 at 11:11am
Software is here: http://muple.com/shop/shop_detail_pds.asp?goods_code=0903090002
I had to reformat my usb stick (fat format) to get the unit to recognise it.
I would set the high-pass at 30Hz to start with, unless you have a ground-shaker of a PA system.
Posted By: IainB
Date Posted: 23 March 2017 at 12:24pm
Absolute star, thank you Smile that is SO much easier to understand whats going on
Im sure im getting dyslexic, that should have been 40-100! I am an idiot at times Confused
USB stick is already sorted, its even in the same brushed aluminium finish of the VSX and 256mb
Date Posted: 23 March 2017 at 12:30pm
Peavey sent me the software which I believe is in the link above.
I do not claim to be an expert but what I did with the limiters is use this calculator: http://www.poulpetersen.dk/Appn/gblimthc.html" rel="nofollow - http://www.poulpetersen.dk/Appn/gblimthc.html in order to calculate the maximum RMS voltage that I would like to feed to my speakers based on speaker wattage and impedance. I would then feed a sine wave signal into the crossover input. I had a stand alone sine wave generator but you could download one onto your phone/laptop. The next thing I did was select a sine wave frequency between my 2 crossover points. eg for bass 40HZ to 100HZ I would use 70HZ. Next I would connect my multimeter to the bass amp output (with no speakers connected) and increase the sine wave input level into the crossover. monitoring my multimeter voltage to ensure that the limiter limited the output voltage to where I had set it. If it went past that level I would lower the limiter threshold. so that increasing the sine wave input would not increase the amplifier voltage output past the voltage I had calculated. This was repeated for the mid and top amplifiers on both left and right channels to ensure that the limiters engaged at the desired levels.
In my case I limited the output voltages to 70% of the maximum voltages as any higher level was not required and I would not have been there to monitor the rig.
I did not conenct the software to the crossover but used it to create a file with my crossover points, limiter settings, delay and eq. This was then uploaded to the crossover using a memory stick.
Regards,
Mike
Posted By: IainB
Date Posted: 23 March 2017 at 12:45pm
Thanks Mike.
I know the software wont do a direct connection between laptop and VSX (spent way too many hours on the Peavey forum digging for info). Just glad I have the software so I can see it on the laptop screen, save to USB, import from USB to VSX and see if it works.
Thanks for the info on setting the limiters, one of my jobs for today is to play around with the inbuilt signal generator on the VSX and make sure my amps are set to the 'expected' output settings then do the limiter settings and give it all a test tomorrow.
Just a shame that a) the peavey forum is dead b) not many people use this LMS and c) I buy stuff without looking into it enough!
Date Posted: 23 March 2017 at 1:20pm
Your welcome. I am sure you'll be pleased. At least you'll have a good understanding of how it works and it will serve the purpose well.
Posted By: IainB
Date Posted: 23 March 2017 at 1:41pm
Quick stupid question Mike... the calculator in the link you posted
I have 2 sets of speakers both 8ohm @ 500w, the amp will see these as a 4 ohm load
In the calculator im assuming I use the 4ohm @ 500w measurement (which makes total sense now Ive started typing it out. (as you can see this is all new to me, im usually 'plug and play'))
Posted By: IainB
Date Posted: 23 March 2017 at 6:30pm
Ignore the above, have been doing maths for limiters LOL using something I lifted off the Peavey site, example below
20log (((SQRT(200*8) / 40) / 0.775) = 2.2139
Now happy setting this up (nearly) just need to check the levels coming out the amp and im sorted, or at least enough to get this up and running Clap if it was easy, everyone would be doing it..
Date Posted: 23 March 2017 at 7:39pm
Your making progress. One thing I would confirm is that your meter can read high frequency voltages accurately. This should be documented in the meter specifications.
Posted By: IainB
Date Posted: 24 March 2017 at 5:54pm
Much faffing around with the VSX managed to get the right level out the signal generator, into the amp, which are now all marked at x40
Settings all on laptop for my speakers, will transfer that over to the VSX tomorrow and annoy the neighbours, im SO lucky the other half doesnt mind have 6 speakers in the front room + amp rack.
Im following all the advice Ive been given, so it 'should' work.
I will leave the understanding of all the mathematics until after the gig, but at least im comfortable everything is now set as to what the VSX is expecting will be happening amp wise
Posted By: IainB
Date Posted: 25 March 2017 at 1:13pm
Something weird going on with the VSX. I had 2 x 2 ways set up, but only one bass output working, however the inbuilt sine wave generator outputs on... all 6.
Couldn't figure what Ive done so built 2 x 3 way crossovers, first I crossed at 20/20 then muted outputs on the VSX and moved the bins and tops along one to 2 & 5 & 3 & 6, all works fine so Ive saved that it memory and back onto USB.
Will play around with the non working one and see what I can work out WTF ive done!
Didnt run it up full pelt, but does sound nice, dropped the tops by 4db, no EQ setup, im happy Smile
Posted By: Wael abdelhedi
Date Posted: 02 May 2024 at 9:31pm
Hello bro ..please i need your help
I have a vsx 26
But i lost the CD of software ...and i need the software of the vsx if you have it please
Posted By: APW
Date Posted: 03 May 2024 at 8:26am
Originally posted by Wael abdelhedi Wael abdelhedi wrote:
I have a vsx 26
https://peaveycommercialaudio.com/software/" rel="nofollow - https://peaveycommercialaudio.com/software/
Posted By: A Douglas
Date Posted: 05 April 2025 at 11:16am
Hey’ good day…
I just stumbled across your post about acquiring the VSX26 software… I myself have been searching a few years for this software and I’m just wondering if possible’ if you could sell me a copy? Id be grateful if you could.
I await your response…
A Douglas
Date Posted: 05 April 2025 at 5:41pm
Hey’ good day…
A Douglas
