Crest 8001 - Value
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=97861
Printed Date: 16 April 2024 at 8:33am
Topic: Crest 8001 - Value
Posted By: levyte357-
Subject: Crest 8001 - Value
Date Posted: 21 February 2017 at 1:30am
Been offered 20 year old version of one of these, wonder what the people here think it is worth !?
Told years ago, certain version  is headache to repair/service, assuming it's the older one?
Confused
Posted By: B_Bender
Date Posted: 21 February 2017 at 5:15am
A 20 year old power amp. £100...?
Full re-cap would be required, major cleaning job as well.
Date Posted: 21 February 2017 at 9:06am
Price entirely dependent on condition Lev,is the same with a 20 or even 30 year old Crown,a lovely clean one will appeal to the hifi bods and make a good price,a scruffy one,well,as mentioned above,£100-ish.
Date Posted: 21 February 2017 at 10:03am
Thsnks guys.
Wouldn't even consider it, if it wasn't 8001.
Wondering if it will be money pit, like buying classic car.
Posted By: U.Viktor
Date Posted: 21 February 2017 at 12:31pm
Most of you thinking about only Electrolyte capacitors what seriously defines lifetime of power electronics (amplifiers).
Unfortunately this is not so simple in practice, power semiconductors also have "wearing out " effect which depends on how many and how big heating up and cooling down cycles received.
In the analog amplifiers the dissipated energy of the power semiconductor is modulated by twice of the frequency of the amplified signal. Sharp temperature changes in the junction layer making some changes in the crystalline structure of the semiconductor, which may results failure sooner or later.
This effect is present in switching-type of semiconductors (sw MOSFET, IGBT) too , but their structures have been designed to better handle this issue.
Sorry to say this but the time has well went over the type of dissipative circuitry (analog, AB, classH), their linear transistors have never evolved to those levels like the switching couterparts.
It means that the available low number of linear power devices are lagging ~20years back of today's "conventional"  power switching devices, in terms of power cycling capability, reliability, maturity of crystalline structures.
Date Posted: 21 February 2017 at 12:44pm
Mein Gott, I 100% agree with one of Victor's posts!!! LOL
Posted By: Earplug
Date Posted: 21 February 2017 at 3:33pm
"Mein Gott, I 100% agree with one of Victor's posts!!! "
Now that is worrying!   LOL
"Sorry to say this but the time has well went over the type of dissipative circuitry (analog, AB, classH), their linear transistors have never evolved to those levels like the switching couterparts."
That's quite a sweeping statement. I still have amps made from/around the old Maplin/Hitachi MOSFET modules working fine after 30 years, never mind my Crests, etc. One guy I know recently got rid of his Ram Audio lightweights and replaced with 8001's. He's never been happier.
And how would you define something like Lab Class TD - analogue or 'digital'?
On the subject of the 8001, one thing you could do is stick a multimeter on the output and see if there's any (DC) drift. That is quite a good signal of the health of the amp.
Posted By: U.Viktor
Date Posted: 21 February 2017 at 7:28pm
The Crest 8001 is a 2x 1200W (4Ohm) amplifier as far as I remember. May deliver 1800W peaks on 4R load for short periods... Its weight is ~40kg, consumes 3 or 4 rack unit spaces, has terrible power factor, poisoning mains with injected current peaks, its power valid only rock solid 220Vac due non regulated power supply..
Despite its large number of output transistors, did not perform very well on certain speakers because the output stage did not like largely shifted output current vs. voltage due heavy dissipation in the endstage.
As I remember it has a momentary U*I dissipation protection per output transistor arm and causes terrible sound effects when acted sometimes ;_)
So let us say the linear amp has made to deliver 50A peaks but if you have just half the output Voltage the output momentary current shall not exceeds 25A, which is typical with resistive loads.
Unfortunately the real speakers like to act as motors//generators so sometimes the maximum source and/or sinking current capability of endstage is required not only at time of peak Voltage events..
Here most of the linear amplifiers fall and properly constructed class-D win, which can deliver (or sink) its nominal output current at ANY output Voltage without the risk of exceeding momentary dissipation limits of the output power devices. This small trick is the secret sauce of good speaker control, what nobody tells you.
Posted By: nickyburnell
Date Posted: 21 February 2017 at 8:47pm
This is brilliant. You keep up all the negativity and persuade the sheep they are all useless now. The rest of us will then rejoice is a market flooded with £100 8001's and PPX's etc.  Good job, keep up the good workThumbs Up
Wow, sound must have been shit for the last 20 years
Posted By: luton_soundman
Date Posted: 21 February 2017 at 9:28pm
From the guy who loves pkn
Posted By: kedwardsleisure
Date Posted: 21 February 2017 at 10:16pm
Parts for those old crests are getting dear now.
A set of electrolytics could be as much as £450. You will find out if they've failed when they spurt boiling electrolyte all over the board in the middle of a bass drop.
North Staffordshire
Date Posted: 21 February 2017 at 10:39pm
Better start a Crest breakers yard then :)
Date Posted: 21 February 2017 at 10:57pm
to be fair the CA series have been coming in with vented capacitors for a few years now, so not just the 7/8/9000 series. Luckily a set of caps for a CA12 is only £150-200 trade but they aren't as big as the ones in an 8000
North Staffordshire
Posted By: sajti
Date Posted: 22 February 2017 at 5:40am
8001 was my favourite amplifier to drive the bass. Of course it was about 20 years ago. I don't agree, with Viktor, this amplifier has very good sound, it was well designed, bullet proof build.
We had about 20 pcs. and we lost only 2 channels in 4 years, even with heavy disco usage. It was easy to repair, and even easy to make it more powerful :)
Agree, that the capacitors are expensive, but it's quite checp to replace them with the new snap in version, with a small pcb.
Sajti
Date Posted: 22 February 2017 at 11:36am
Its amazing how so called crap tha are
still dropping heavy the old crest still doing the rounds
in the soundsystem scene
come on ppls, agreed nik
Date Posted: 22 February 2017 at 11:39am
We know tha hold there price,
not 100% bout the really old ones,
but tha still going rate can be 400-500 depends on condtion
my 2p man love crest all day man, wernt 3/4 grand new for nothing oo series....but do understand the age thing with them..
Posted By: Earplug
Date Posted: 22 February 2017 at 12:36pm
"I don't agree, with Viktor, this amplifier has very good sound, it was well designed, bullet proof build."
+100
Mine even survived getting plugged into 480v once (yes, I know: Meter Your Mains). The input switch-cum-breaker popped and that's all. After the mains were put back in place, they powered up & worked perfectly. I'd like to see how many (modern) amps could match that.   Thumbs Up
