XKitz "all in one" amp / bluetooth / bms
Forum Name: 12v Powered Systems
Forum Description: From Mini-rigs to ICE, all your low voltage audio needs here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=98411
Printed Date: 18 April 2024 at 2:39pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: XKitz "all in one" amp / bluetooth / bms
Posted By: bitSmasher
Subject: XKitz "all in one" amp / bluetooth / bms
Date Posted: 29 April 2017 at 6:18am
I've followed XKitz for a while, as their products interest me... though I haven't had a need for any of it: https://www.xkitz.com" rel="nofollow - https://www.xkitz.com
They've been posting on Instagram about an upcoming "all in one" module for portable bluetooth speakers, with details finally released: https://www.krowdster.co/l/e447" rel="nofollow - https://www.krowdster.co/l/e447
I'll copy/paste the blurb below.
As I've posted in another thread, I'm playing with the Sure JAB2 and expect (& hope) the XKitz to be more of a premium option. JAB2 Discussion here: http://forum.speakerplans.com/sure-jab-2-all-in-one-amp-bluetooth-bms_topic96581.html" rel="nofollow - http://forum.speakerplans.com/sure-jab-2-all-in-one-amp-bluetooth-bms_topic96581.html
Anyone else seen this, and what do you think?
------------- https://www.instagram.com/batteryacidsoundsystem/
Date Posted: 29 April 2017 at 6:19am
PORTABLE SPEAKER INTEGRATED AMPLIFIER AND CONTROLLER
Combines all the functions of a portable Bluetooth speaker into one compact and tightly integrated module Bluetooth v4.2 Audio Front End Active Crossovers and DSP Audio Processor 2.1 Class-D amplifiers with 250W RMS combined power 250W Lithium-Ion power supply for fully wireless portable operation Power saving features to extend battery life All built on a compact plate module Designed and built for the highest possible audio quality Bluetooth streaming AAC format - not the low quality SBC format used by most Bluetooth speakers that gives Bluetooth audio a bad reputation Active Bi-Amped topology for the ultimate crystal clear audio - no need for expensive passive crossovers that only distort your sound and waste half of your battery power High Definition 24 bit/96KHz DSP audio processing Ultra low distortion Class-D amplifiers Audio Front End Bluetooth v4.2 with AAC streaming and up to 24bit/96KHz audio Analog line-level input with 24bit/96KHz sampling Active Crossovers and DSP Audio Processor Linkwitz-Riley Active Crossover User programmable audio parameters: Crossover frequency and gain Crossover roll-off: 24dB or 48dB 15 band EQ Time delay correction Baffle Step Compensation Compressor/Limiter to prevent the amplifier from ever going into clipping Optional audio enhancements like Spatializer and Dynamic Bass Boost Class D Amplifiers 250W combined power 2.1 Configuration – One center sub-woofer and two tweeter channels 125W RMS to the woofer 62W RMS to the tweeters TAS5611A Class-D Amplifier: 10Hz-80KHz Signal Bandwidth 0.03% THD+N >100dB SNR No fan needed Lithium-Ion Power Supply 250W 2-Phase DC/DC converter - steps up the 14.8V Lithium-Ion battery voltage to 24V-30V needed by the amplifier Integrated LiIon/LiPo charge controller Dynamic Voltage Scaling – automatically turns up the voltage when you crank the volume and the amplifiers need the extra power, then turns it back down when not needed to save battery life Multiple levels of electrical and thermal protection to prevent Lithium-Ion battery damage DSP User Programmability - Similar to mini-DSP For those intrepid souls who want to delve deeper into the DSP programming and configuration, we expose the programming interface to the DSP chip to allow you to use SigmaStudio from Analog Devices to customize the audio processing to support any specialized functions you need. SigmaStudio is a very simple drag and drop programming interface, no need for specialized DSP programming expertise. The DSP functions available are similar to those in the mini-DSP system.
Posted By: carlosdelondres
Date Posted: 10 May 2017 at 10:24am
Looks good - just had an email from Sure saying they'll be releaseing a 'JAB3' with more power and DSP in the next 2-3 weeks...will be interesting to compare the specs ;)
Posted By: lutkeveld
Date Posted: 10 May 2017 at 2:14pm
Is there any more info in the mail? Sounds interesting
Date Posted: 10 May 2017 at 2:29pm
nope, no more than the above. Will post back if I hear anything more...
Posted By: mini-mad
Date Posted: 10 May 2017 at 10:08pm
..all that at 10%THD?
------------- If it sounds like a gorilla is trying to escape, turn it down.
Date Posted: 18 May 2017 at 11:15am
They sent me the brochure, the JAB3 looks quite interesting - same amp options as the JAB1/2, but with the DSP module, and a connector to integrate with a JAB1/2. So JAB1/2 with JAB 3 gives you all the input and power options (MPPT, 18650 3S BMS/holder, bluetooth and analogue inputs), with 4 channels of DSP. They have programming interfaces to use Sigma Studio gui for the dsp configuration. Should be pretty sweet. $34.90 for the 2x50w version apparently!
Posted By: Padde298
Date Posted: 15 June 2017 at 11:00am
#following :-)
------------- LOUDER!!! MO BASS
Posted By: Edd Jordan
Date Posted: 16 June 2017 at 11:59pm
whats happening?
------------- I do a sideline in ply wood wheels.
