scoop bass
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=9854
Printed Date: 27 March 2026 at 8:24am
Topic: scoop bass
Posted By: Dubplayer
Subject: scoop bass
Date Posted: 06 May 2007 at 6:37pm
I want to build my first scoop bass
coul anyone post a picture( as answer to this question) how is the conection between speaker and speakon?i mean "the way" inside of scoop bass.is necesary stick this wire to the internals pannels of scoop?
thank very much
Posted By: Insomnia
Date Posted: 06 May 2007 at 7:10pm
Hi mate-
u may get a few different veiw from other people-
i run the cable through the horn path-no hole drilling etc- u can tack it down if u wish-
i know others drill holes through the panels then seal them-
Date Posted: 06 May 2007 at 8:09pm
is possible a draw to see it.i never have seen it before.thanks!
Posted By: jethrocker
Date Posted: 08 May 2007 at 9:59pm
I also ran the cable through horn path, easier to do when you only remember to consider fitting cables at last minute before the side panel goes on..
I stapled cable ties to the woodwork along the route the cable takes round the bends and used those to fix the cable in place...
