problem with Robe 250ct scans in master and slave |
supremesoundz
Old Croc Joined: 26 January 2009 Location: London Status: Offline Points: 2689 |
Posted: 17 July 2011 at 10:53am |
as above, these things did my head in at a small gig yesterday! Admitidely, I havent used these in a while and had them linked up in master and slave mode. They would would work for 10 seconds and then stop. If you pressed run again, they would repeat the sequence and then the same thing happened again.. Lucky it was a family party in a small marquee and lighting wasnt that important
norty303
Could be in timer mode, with a long time set.
supremesoundz
yeh, I tried several times to go into audio mode, powered the scans off and on again to reset them. Will have another go tomorrow
