Problem with T.amp ta2400 |
Pasteman
Registered User Joined: 23 June 2009 Location: Leeds Status: Offline Points: 185 |
Posted: 07 March 2010 at 10:17pm |
Got given this second hand and not working, amp turns on, fans move, fault light comes on then disapears on both channels after 2 secs as supposed to, clip lights on constantly till speakons are connected then just the active lights remain. when a clean and tested signal is played through the amp it appears distorted and crackly through the speakers it happens on both channels, all modes, binding posts and speakons has anyone had this fault? can it be fixed or diagnosed in anyway? anyone know of a good amp repair man leeds way?
Thanks for you time and patience. |
service dept Steve
Old Croc Joined: 30 January 2010 Location: S.W.London Status: Offline Points: 2034 |
I'm not anywhere near Leeds but you can post it to me in Shepperton studios if you like.
Just check it isn't a pair of dirty pots, anyone local can do those for you. Steve |
We are not "They", We are "The others"http://www.servicedept.co.uk -
Pasteman
thanks for your reply
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
This sounds like the amp has lost its bias, these are the symptoms they give. The amp oscillates about the crossover point with no load, causing the bottom VU meter leds to come on, sometimes they flicker. Putting it on load with no signal sometimes helps it to settle down. If you scope the output you get a small square wave or random 'morse code' effect.
It's not unusual for both channels to suffer the same thing, i guess it depends how heavy handed the operative was who originally set it up. If it is worse when the amp is very cold, but its better on a warm day, this clinches it. Just a thought, you might of course have a weird one. Edited by kedwardsleisure - 22 March 2010 at 8:03pm |
North Staffordshire |
Pasteman
problem solved replaced 2 faulty bridge rectifiers, serviced, and working as should
Alex_C
Registered User Joined: 13 April 2006 Location: Leeds Status: Offline Points: 180 |
just seen this thread and i'm glad to hear you got it sorted... who did it in the end?
For future referance Jas at Astral is good, the company i work for has been using him for a couple of years and have always been very happy with the results. http://www.astralsonictech.co.uk/index.html |
kedwardsleisure
let me guess the pins had fractured internally |
smithlanger1
New Member Joined: 01 June 2010 Status: Offline Points: 1 |
sounds good to me
Pasteman
yep fractured pins, just found replacement parts and resoldered in place, still working fine
2 people use this account but they say 2 brains are better than one...
service dept Steve
Probably had left handed ones fitted in the first place.
chriscov4u
New Member Joined: 15 November 2011 Status: Offline Points: 4 |
I know this is an old string but I have a AH2400 with what looks like an identical fault, any chance of a detailed explanation of the cure??? (component locations and numbers etc for testing, anything really!!)
Tonskulus
Registered User Joined: 15 September 2017 Location: Finland Status: Offline Points: 425 |
I have one too, Tamp TA-1400. Ch2 clip light on, speaker output reads 8.4volts DC.
Resoldered and checked all bridge rectifiers, they seem to be ok. edit: I had to change one rectifier (high rail), now it's working :) Edited by Tonskulus - 23 October 2017 at 3:15pm |
