Problems with 18" project |
13Tez ![]() Registered User ![]() Joined: 23 December 2008 Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 23 December 2008 at 10:23pm |
Hi all this is my first post so here goes:
Ive been fiddling around with ht audio bass pro 6 for some time now, Im trying to design a vented cab (for playing bass guitar through) I really want something that can go lower than 40Hz, som where around 30-35Hz would be good. Been looking at the celestion ftr18 4080fd. However after finally getting the desired cut off frequencies, I checked through the other grahps given by bass pro and it seems the driver would struggle, at some frequencies, handling the 500w input.
Im no expert at all this so can anyone point out where Im going wrong? Ive tried everything on bass pro from box size to port size etc. Ive tried a different driver one with a bigger Xmax and it performed much better, could it just be the driver?
Any help would be great.
_djk_ ![]() Old Croc ![]() Joined: 23 November 2004 Location: United States Status: Offline Points: 6002 |
You're fine with bass guitar if you go beyond x-max.
It's sine-sweeps where you get into trouble.
djk
Elliot Thompson ![]() Old Croc ![]() ![]() Joined: 02 April 2004 Location: United States Status: Offline Points: 5114 |
Try a 183.6 liter (Internal) box tuned to 35 Hertz. You should be at 36 Hertz - 3dB (36.52 Hz f3) Normalised Gain with the Celestion FTR 18 4080FD driver. Best Regards, Edited by Elliot Thompson - 24 December 2008 at 5:03am |
Brilliant! Thanks for all the advice, got a graph now that looks rather tasty
![]() Edited by 13Tez - 24 December 2008 at 9:48am |
Punch these numbers in Bass Box Pro Vb: 183.6 Liters Fb: 37 Hz QL: 7 Your Maximum Electrical Input Power should be 1000 watts from 100 - 34.7 Hz with an f3 of 36.82 Hertz. Normalised Gain should say 36.7 @ -3 dB Bare in mind the xmax is 12 mm so, you should not encounter any problems from 30.6 - 100 Hz feeding it a 1000 watt amplifier. The Xmech is 18 mm one way or 36 peak to peak. If I can feed the older Celestions that offer an xmech of 16 mm one way 1000 - 1500 watts without them damaging, this driver will handle 1000 watts as well. ![]() Best Regards, Edited by Elliot Thompson - 24 December 2008 at 12:32pm |
aperrado ![]() Registered User ![]() ![]() Joined: 10 January 2008 Location: california Status: Offline Points: 315 |
where can i get bass pro ?
Im hard to learn but still asking
tomschute ![]() Old Croc ![]() Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
Interesting... so with regards to "electronic" music what would you regard as a safe tolerence to work too for pushing you drivers past there x max? Obviously it's not an option i'd like to take but i'm trying to box some 15" mckenzies and with 4.5mm x max i'm getting alot of probs keeping excusion below 5.5mm to 6mm with the desired freq range wanted... am I gonna kill them... again... oh and Bass Box Pro available at http://www.ht-audio.com/ Edited by tomschute - 29 December 2008 at 8:18pm |
www.stableaudio.co.uk Speaker Building Services |
