Projected finished , 18 inch J reflex |
Post Reply | Page <123> |
csg
That looks like a really good effort for your first build, and a good effort with the jigsaw on the driver cutout, ive seen much worse!
Not wishing to be negative but I hope that you did not pay too much for your plywood, that aint birch ply, 18mm birch ply would typically have around 13 laminates and if BB grade, as typically used, would have had it’s knots patched to give a smooth void free surface.
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
^ this 100%, also birch tends to be very light in colour and has a fine close grain. That looks like softwood shuttering ply. TBH, I have in the past built speakers out of cheap ply and they have lasted for years and sounded absolutely fine, would I do it now… No! What you save in the cost of the ply is normally spent in filler and time trying to make them look half decent… Quality 13 laminate ply is a joy to work with; cheap ply can be a nightmare. Edited by APW - 27 July 2020 at 10:08am |
jordanclarkdj
Registered User Joined: 12 October 2018 Location: UK Status: Offline Points: 91 |
Hi guys, thanks
I ordered 3 sheets of Birch ply and thats what i got delivered, I didn't pay much as I get discount from a friends account who is a builder and gets around 30% discount on all there products anyway and vat free I paid around £17 a sheet If i remember correctly , Im assuming it would have been around £35-45 a sheet at full price
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2572 |
£17 a sheet sounds about right for shuttering ply, they do look good though, tidy job.
jordanclarkdj
No, I paid £17 after my friends discount of 30% then he is vat registered so i didn't pay the extra 20% vat either If I never got it through his account id have paid £35-45 a sheet
jordanclarkdj
You guys are right, I just checked the delivery line and it says on it ' Pine Ply '
Is this still any good? it felt like a reasonable quality, I am mostly going to be using these outdoors will it be ok ? Im looking into getting covers made to protect against the rain
APW
If they are for casual use (“weekend warrior” type stuff) I'd put money on they’ll last you for years and I doubt you will notice much difference in the sound. |
jordanclarkdj
Yeah they won't be used every weekend , probably 10-15 times a year at max
djeddie
Should be fine in that case. Well done on the build... and putting up pics of someone making sawdust!!!
csg
I would not worry, at £17 a sheet you won’t do much better. Might do to check if it is “WBP” plywood, if it is not and is sitting in water etc it might de-laminate..but lots of expensive boxes from bog names are made from similar ply.
jordanclarkdj
These will be kept in dry storage when not in use and if outdoors and rain comes on I will have covers made for them eventually
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
Shouldn't worry about the ply too much.
Id probably revisit the speakons though.
