  New Posts New Posts RSS Feed - Projected finished , 18 inch J reflex
jordanclarkdj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jordanclarkdj Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 11:59am
Originally posted by Digbethdave Digbethdave wrote:
Shouldn't worry about the ply too much.
Id probably revisit the speakons though.
What is wrong with the speakons ?
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 1:03pm
A bit of heat shrink tube over the soldered ends would be a good idea to prevent potential shorting out in the future. But as long as the solder joints are strong and tidy i think you will be fine..
Reverence Sound system
www.mixcloud.com/B1_Jams/
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 1:22pm
Yes, was about the say the same. The usual route is to solder all vertical and then heatshrink but your work looks pretty tidy and I don;t think you will have a problem.
However it is worth a nod to the worst case of one joint detatching under vibration/stress and contacting its neighbour while the amplifer is at full tilt. Expensive possibility for the sake of a bit of heatshrink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jordanclarkdj Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 3:08pm
Yeah I never thought about that guys,  I will order some just now then. Do I need to put it over the actual solder onto the speakon and cover it all so you cant see it or just enough that it covers majority of it
Post Options Post Options   Thanks (0) Thanks(0)   Quote jordanclarkdj Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 3:21pm
Curious but what sort of value would these be worth if I was to buy them knew,  the drivers in them were £200 each, I reckon parts/material has cost me around £600   thats before 24hours labour and the tools I had to buy to do the job
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 3:53pm
When done correctly the heatshrink will cover all of the exposed wire and terminal per wire. You'll need to unsolder, put heatshrink onto the wire, re-solder, slide it down then shrink it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jordanclarkdj Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 7:08pm
would wrapping electrical tape around it do the same job rather than me having to un solder everything
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 8:50pm
Electrical tape wont do the same job, generally after a year or so the adhesive goes soft and the tape looses its grip. Heatshrink will last forever.
That said, personally, over the course of 25 odd years and countless speaker cabs i have never used heatshrink in this way. Im not saying you should not, just that I'm confident in my soldering and have never suffered a joint failure or short. Your call.
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2020 at 10:38pm
Have to agree, this is true. Even from an early age where my soldering could be considered of dubious quality, have never had a solder joint detach. But heatsink is cheap, looks good to boot, and keeps any stray whiskers under control.
That said, if you're confident in your soldering just use them. There's very little chance of a problem. I'd make the changes if it was me but its your call.
