Projector |
Post Reply | Page <123> |
Muckerbarnes1
Old Croc Joined: 20 March 2010 Location: Stroud Status: Offline Points: 2654 |
Rich, you are talking a short throw distance there.
For example this fairly std throw of 1.5:1 proj 5K lumens is 1500 quid; This is 1920 x 1200 WUXGA. This is the ideal format you are looking for. Fitted hundreds of the things. Talk to the people above. Ask for Shane. Cheers. Mucker.
Billy Dawg.
nuclearbass
Old Croc Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
Cheers Malc 👍
Nearly ended up putting a 19" LCD in there 🙄 |
one life - have fun!
Force fusion pro audio |
MattStolton
Close, but i reckon he needs 1.4:1 for 6m through to 5m wide, so something 1.5-1:1. 1.5 puts his lens at 7.5m from a 5m wide screen. Equally, a 5m wide screen, 16:10, will require, at only 50 lumens /sq ft, 16.4ftx10.2ftx50= roughly 8500 Lumens. 5K Lumens will not be bright enough in dim ambient light, any other light and it will be shite and washed out. 2 stitched/overlapping may be good enough, depending on ambient light. But you need projectors with this option, which adds to cost per unit. Either way, budget is fooked.
Muckerbarnes1
Yes. Read the budget! It was as stated an example
Regardless of personal opinion on how bright we believe it is all off spec. Throw, size and budget. Simple remedy. Get one in budget with a screen that fits both room/proj. Buy some blinds. Simple answer. The times I've specced such and it was just a waste. I remember fitting 5k lumen projectors when they were £30K. Mental. Or the huge 4ft long Barco crt units that cost even more. All silly. Buy one for 500 quid and make it work well. Spend the rest on a holiday or a 19" LCD and a better holiday.
Edited by Muckerbarnes1 - 25 November 2016 at 11:47am |
Billy Dawg.
toastyghost
At our sports bar I personally much prefer the 85" 4K telly to the 135" projector anyway...
MattStolton
Totally Agree.
MattStolton
I know most will think them third world, but AVSL have some pretty nice motorised 2.4 wide 4:3 or 16:10 for absolute pennies. By two for even cheaper each!! I won't say exactly how much, but buying two at a time, only just gets you over carriage free limit!
Installed a 4:3 one in a school, and couldn't understand why so cheap. Nice to install, works flawlessly, with wireless (radio) remote!! Even the electronic stops were a nice thing to adjust, and very quick to get right.
Soundscape
Registered User Joined: 09 March 2008 Location: United Kingdom Status: Offline Points: 416 |
Sorry if this might be hijacking the thread somewhat but can I pick your collective brains please as regards a video switch box?
I know of Kramer as a maker of a large variety of kit for video applications. Can you recommend one of their models (prefer a rack mount unit) that will take video o/p from my laptop and split the signal up to say, 6 ways, i.e. 1 x projector plus 4 or 5 TV screens (not necessarily in a matrix). Thanks! Steve / Soundscape
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Offline Points: 2155 |
VGA, DVI or hdmi?
Soundscape
The DAP DVMP-250 DVD media player I have has both an HD15 and HDMI output so might there be a Kramer or, other make of switch that would take either type of input? This is new territory for me so I'm keen to learn Thanks for any advice you can offer. Steve / Soundscape
toastyghost
How far do you need the longest cable run to be?
Soundscape
Approx. 25M max at the venue I'm working in next week.
I do have easy access to vga cables of up to 50M if needed. I gather there's a limit when using HDMI cables before possible signal degradation depending on where the cable is placed. But opinions vary as to what the distance is before repeaters are needed (?) I doubt it's critical to show the short video I've been given in HDMI so vga cables ought to be ok. Any knowledge and experience on this subject very much appreciated. Steve / Soundscape
