  New Posts New Posts RSS Feed - projectors??
projectors??
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Topic: projectors??
    Posted: 27 April 2009 at 4:06pm
I've been asked by a customer for a projector to project 'branding logo's' onto quite a small space approx 100cm x 60cm, multi logos that can be easily changed so that rules out the single gobo projectors.
Would an LCD project be able to do this? then the source could be from a PC / DVD.
TIA
Don't worry F$cked up bigger gigs than this one...........
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2009 at 4:38pm
yes an lcd rojector could do that, alltho dlp projectrs are better in the long run as the bulbs dont dim. lcd projector bulbs tend to get dimmer about 500 hours in to their life.
and also the projector must have vga and comsit inputs for dvd/pc
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2009 at 9:26am
why is that then ? - is that an artifact of the chip, as both projectors tend to use ultra high presure ( UHP) mercury arc lamps.
personally i can not stand small / cheap dlp projectors as you get the rainbow effect from the colour wheel
you can get muti slide projector units from optikinetics, but they cost, and a projector would probably be a simpler and cheaper solution
Edited by csg - 28 April 2009 at 9:28am
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2009 at 9:49am
What i was thinking was a very basic domestic unit - think home LCD projector BUT can it project an image down to say 100cm x 60cm from a distance of about 4-6M
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2009 at 10:24am
Most domestic projectors will struggle to project an image that small from that distance - they are equipped with very short throw lenses in general
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2009 at 11:17am
Having a quick google its seems alot of cheapy domestic units will do an image of 2.5ft diagonal - what would be the minium distance from projector to screen? Sorry this is new to me always been a noise boy!
