  New Posts New Posts RSS Feed - Proline 2700/3000
Proline 2700/3000
mattd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattd Quote  Post ReplyReply Direct Link To This Post Topic: Proline 2700/3000
    Posted: 18 April 2012 at 10:42am
So people seem very happy with these. I am with mine.
Was wondering has anyone had any issues at all with them - any failures -  faults etc ?
geoSal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geoSal Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2012 at 12:10pm
the power switch in the front is a cheap component and it's a matter of time to fail.
it did it to mine unfortunately during a gig.replaced it with a better one and everything ok since then.
No other problems.plenty of power but only for sub or mid bass duties.not very clean and fast for mid-hi..
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2012 at 12:51pm
There is a thread by DJ Leco around here somewhere, regarding  updating certain components in the inrush circuitry.
http://forum.speakerplans.com/the-amplifier-internals-thread_topic23787_post381426.html?KW=Proline+2700#381426
Originally posted by DJLeco DJLeco wrote:
Mine club amplifier, saturday it have sudden death...
Working on 2,66 ohm/channel/mid-hi 110 Hz above.
Died NTC thermistors 10 ohm  from inrush current limmiter circuit.
But oficially, those must been shorted by blue relais after 2-3 seconds from startup, but relais doesnt receive 24 volts for coil...
TO ALL OWNERS OF PROLINE 2700,PROLINE 3000, SI PHONIC, check and better , REPLACE, parralel diode on relais coil  (D503 at  Proline 2700 si 3000),Specially if is 1N4148 with 1N4007.
Also replace the transistor wich commands the 24Vdc for relais coil (TR503 at Proline 2700 si 3000), officialy is C2240 (2SC2240) with BD139 or better, BD237.
As ideea, the ones wich have Proline 2700, or Proline 3000 amps, and found those NTC thermistors burned, the relais doesn't work well.
Amp 1:
Burned PCB:
Output devices, originals ON Semiconductor:
Final stage Ch1:
Trafo:
NTC:
NTC differency with the ones that I put there:
NTC changed:
Secondary Cu-Em, just 1,5mm diameter, TOO TINY!!
Soft start:
Here is where must be changed those transistors and diode!
[size=16]Small movies:
Inrush current limmiter now working!:
Prezentare+1Ch @ 1000 Hz ,max 76,5 Vrms-4 ohm:
Ch1+Ch2 @ 1000 Hz/4 ohm:
Ch1+Ch2 @ 100 Hz/4 ohm:
Ch1+Ch2 @ 30 Hz/4 ohm:
Ch1+Ch2 @ 5000 Hz/4 ohm:
Ch1+Ch2 @ 10000 Hz/4 ohm:
Ch1+Ch2 @ 20000 Hz/4 ohm:
Just Ch 1 @1000Hz and 100 Hz/2 ohm:
Just Ch 1 @30 Hz-2 ohm
Just Ch 1 @100 Hz/2 ohm supply voltage dropping:
Advantages and disadvantages:
Comments or questions,are welcomed!
Edited by levyte357 - 18 April 2012 at 1:22pm
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2012 at 11:58pm
The few around us all the owners are well over the moon with them and their performance on sub!
Not yet!
**Heavy Weight-Line**
