Proline 3000 Channel A Not Working |
junoprobelaunch
Registered User Joined: 01 April 2018 Location: Devon Status: Offline Points: 298 |
Posted: 06 October 2018 at 3:54pm |
Hi setting up two es18s off a proline and for whatever reason channel Aisn't working. Running into usb decks to a DP24 then into the proline but can't for the life of me figure out why channel a isnt working. Both cabs work on B! If anyone has had this problem or knows how to fix it it would be massively appreciated.
djeddie
Have you swapped the input connectors over? Checked any switches on the back?
junoprobelaunch
Have checked switches on back and everything looks good , i initially had it plugged into the B input but then swapped it to the A input and now only channel A is working.
junoprobelaunch
Only got one input plugged in but surely should be able to play two channels of one input ?
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
you got the switch set to parallel?
Reverence Sound system
junoprobelaunch
No, it's on stereo. Should it be on parallel ? Each box only has one connector at the moment.
cravings
paralell means the signal you input to channel A will also come out on channel b.
junoprobelaunch
so to run four off the amp you'd connect a second connector to each cab and connect them up ?
dj jammin
bit lost here.. do you want the single input to go to both output channels? or is that you had both boxes connected to channel a and input to channel a, then swapped to input b and both speakers connected to channel b outputs?
junoprobelaunch
got two Es18s wanted to run one of each channel with one input. switched to parallel and is working but was talking about running 4 in my earlier post
bassdesigner
Registered User Joined: 17 July 2016 Location: Lancashire Status: Offline Points: 228 |
Sounds like a problem with your cables, if the amp is working in parralel modeits unlikely there is anything major wrong with the amplifier
dj jammin
yeah to run 4 es18 you'd link from one cab to another with a speakon cable (2 cabs on each channel)
