Proline 3000/matrix xp3000 or similar |
Post Reply | Page 12> |
hi-grade
New Member Joined: 11 May 2018 Location: Leeds Status: Offline Points: 9 |
Posted: 11 August 2018 at 12:51am |
Looking for a Proline 3000/Matrix XP3000 or similar (2x1500 4r)
nickyburnell
Proline will kill everything if clipped, even once. Seen XP3000 on bench dummy load test, my own amp in perfect order. No where near 1500 a side. The older model pre XP 3000 did though. Spend more or wait for the Berry NX6000 next month.
hi-grade
For the under 500 mark my alternatives could be a qsc 4050 or a crest 8001. I’m quite sceptical about the berry’s ratings as I will be using it for sub, I won’t be able to get it in time for my giggs too. I prefer a big toroidal amp on bass, the matrix was a recommendation from a friend who powered his scoops off one.
I have heard about the prolines clipping and it’s putting me off a bit despite its decent benchmark figures. I’m powering 2 pd186 hogs (mk1) and possibly 2 186 es18s (if I find something suitable). I’ve seen a matrix xt5000 pop up which looked like it would be upto the job and also the macro tech 3600vz. It’s just very hard to come accross certain amps.
LeruSound
Registered User Joined: 27 August 2015 Status: Offline Points: 171 |
I have one Chevin A3000 for sale but i guess it's not enough for you.
hi-grade
Unfortunately not
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
i think for running 186s the qsc or crest a good option ,crown 3600 good but again bit of a driver killa , i know some one who runs 4 pd186s on a 8001 with very good results :)
Edited by paulus - 11 August 2018 at 12:38pm |
TRENDSETTER SOUND SYSTEM
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1509 |
Funny that about the Crown 3600 being a killer of drivers. I have never blown a driver with one. Still got 5 in my arsenal.
nickyburnell
8001. EV P3000 (it WONT overheat if you get the bias and other adjustments done properly), 4050, big Peavey GPS 3400, Crown 5000. Moving modern a Yamaha T5n will do the job and a few have gone for 7/800. The Peavey although a couple of hundred watts short does almost the same at 40hz as 10k! With the Berry I meant two of them. |
hi-grade
I might be to get my hands on a 8001 (recently serviced) and qsc 4050, out of the two which would you recommend? Will the 8001 have enough power for x4 186s? I want it to be reliable and don’t want to be carrying out too many repairs.
The Yamaha/p3000 are abit out my price range. The peavey amp looks decent, just depends whether I’d be able to find one. |
lickweed
Old Croc Joined: 02 May 2009 Location: leyton Status: Offline Points: 2489 |
http://www.liquidsound.co.uk/
nuclearbass
Old Croc Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
get to 10 posts and no inbox me
I have just the thing ;)
one life - have fun!
Force fusion pro audio |
hi-grade
I’d decided to go for the 8001, what did you have?
