Proline 3000 Powering Hogs Q |
Post Reply | Page <123> |
nickyburnell
This^ AGAIN
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
raoulduke14
Registered User Joined: 22 June 2014 Location: Bristol Status: Offline Points: 76 |
Okay for go it... hahah.
Not powering 4 anyway powering 3 but take all your points on board. Cheers Edited by raoulduke14 - 03 July 2018 at 10:19pm |
raoulduke14
Dunno what this above video is meant to be about personally but cheers for the entertaining video.. hahah
Edited by raoulduke14 - 03 July 2018 at 10:20pm |
raoulduke14
Mixed opinions from everyone bit guess ill find owt for myself wont i :) haha
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Thanks(1)
I don't think that data is misleading. How it's used could be argued though and from those numbers you could get a pretty reasonable estimate for your 40-50Hz figure by interpolation. Needless to say that no matter what playing sums says if your driver measures open circuit after then it's all a bit silly. I'm not an electrical engineer type but would it be very difficult to build some sort of PIP type input module for these things. They do seem to have quite a similar rep and specs to the Crown 3600 driverkiller...
raoulduke14
Ok buh, just a newbie so gimmie some slack haha...
thats to levyte357 btw lol Ease it up.... read nuff forums just asking for advice
Edited by raoulduke14 - 03 July 2018 at 10:28pm |
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1292 |
Thanks(1)
Lev was giving you THE best advice for your situation, he was heavy handed because this has been done before, don't take offence take it as sound advice.
gen0me
Thanks(1)
Misleading cause how does 40hz look on the eq and how does 80hz
rosssss224
Registered User Joined: 25 July 2012 Status: Offline Points: 447 |
Thanks(1)
I read forums, deduced it would be fine, blew 4 drivers, regretted even trying. Now face £££ recone bill and need to get an inf8 instead. Just dont want someone to make my mistake (again)
also bought the proline new for £550 and wont be able to sell it for anything less than £350 but it will make a solid kick amp. If you do use it buy an inline attenuator (-10 or -15dB) to make sure the limiter is catching peaks.
Edited by rosssss224 - 04 July 2018 at 9:28am |
concept-10
More good advice from someone with first hand experience. |
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
You don't need an inline attenuator, It’s got infinitely variable attenuators built (as have most PA amplifiers), you control them using the two large knobs on the front panel of the amp. The more the knobs are turned anticlockwise the greater the attenuation. Look at the markings on the volume controls on QSC, PL, PLX and RMX amplifiers; they are marked in –db increments with 0db fully clockwise and ∞ fully anticlockwise Crest Ca,V, 800x etc. and some Peaveys are also marked using a –db scale. The QSC Powerlight 3’s actually have ‘Atten’ written under the controls. Edited by APW - 04 July 2018 at 10:45am |
