Pulsar chaser.. |
Page 12> |
pscstudio54
Joined: 14 March 2020 Location: Bridgwater Status: Offline Points: 12 |
Topic: Pulsar chaser..Posted: 04 February 2021 at 12:55pm |
Hello,does anybody repair pulsar ten way chasers! I know it's old, like myself, but it has worked ok for forty two years . It Will no longer light all channels or chase much ,like myself...cheers.
service dept Steve
Joined: 30 January 2010 Location: S.W.London Status: Offline Points: 2050 |
Posted: 04 February 2021 at 2:23pm |
It's been a long time since I looked at lighting controllers but if my memory serves me correctly the programme was held in a volitile memory which was maintained by a nicad battery, when the battery fails it leaks on the pcb and also corrupts or clears the programme from the unit. Hopefully I have remembered that incorrectly because it means your unit is land fill if I have. An actual expert will be along in a bit...
We are not "They", We are "The others"http://www.servicedept.co.uk -
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 04 February 2021 at 2:41pm |
Could it just be blown Triacs on some of the channels? these are the components that turn the power on and off, if they are overloaded they get fried. They are usually an easy fix if this is the case. |
GAZ.
Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2428 |
Posted: 04 February 2021 at 3:19pm |
Where are you based?
100% Earth Moving Bass
pscstudio54
Posted: 04 February 2021 at 3:20pm |
I was wondering about the triacs on the missing channels as in my other ancient chaser ,a old njd sc4000 which was used for light screens but it all ways seemed that when that went wrong the channel would stay on all the time but the leds on the front panel would still sequence. I know this is a different make and a bit more complex but it doesn't want to chase and three channels don't go at all.this has been used for just one pin spot per channel forever so I don't think it was overloaded.I fear what Steve says will be truth.one weird thing though is if you put it on reverse mode with pairs pattern the leds light up on the front!!? Thanks people anyway...just wanted to get my money's worth our of it!
pscstudio54
Posted: 04 February 2021 at 3:22pm |
Sorry gaz just missed your post....bridgwater ,Somerset.
GAZ.
Posted: 04 February 2021 at 3:30pm |
Ah you’re a way away from me, otherwise I could have looked at it for you. It’s done well to last as long as it has, and the likelihood is many of the components inside will be well past it due to age. However without seeing it is anybody’s guess
pscstudio54
Posted: 04 February 2021 at 3:38pm |
Yes I think your right .I wonder if there's a new Chinese copy that will last as long.....thanks.
charlynch
Joined: 24 September 2011 Location: Somerset UK Status: Offline Points: 189 |
Posted: 04 February 2021 at 4:09pm |
It might be worth having a chat with Nev of Zen Audio Works in Taunton to see if he can have a look at it for you.
pscstudio54
Posted: 04 February 2021 at 4:57pm |
I will look into that. Actually after just looking inside the unit I really can't see anything obvious at all ,no burn marks or the like and it is spotless inside ,no tumbleweed of dust anywhere....thanks for the heads up.
colint
Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5260 |
Posted: 04 February 2021 at 5:02pm |
Malcom Barnes is your man he's specialist in vintage Dj equipment you can find him here but he is also a member of SP but I can't remember his user name
pscstudio54
Posted: 04 February 2021 at 5:26pm |
Thanks for the info....terrific stuff eveyone
Page 12> |
