Punisher access panel |
Lyndon A
Joined: 15 November 2004 Location: Bristol Status: Offline Points: 536 |
Topic: Punisher access panelPosted: 06 December 2005 at 7:23pm |
What the best way to get an access panel on the Punisher 2? Is it removable battens? Or would a metal access cover be best? Space is really tight for getting the Ciare drive in and out. |
MixMan X
Joined: 18 July 2005 Location: United Kingdom Status: Offline Points: 382 |
Posted: 07 December 2005 at 3:10am |
I used battens in mine, with one removable to get the driver in, you need one each side to do up the screws. Next time I'll use a 6mm aluminum rectangle recessed into the ply, so it won't need any battens, and it will be a lot easier to get air tight.
