  New Posts New Posts RSS Feed - Punisher Extension Development Thread
Dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2019 at 12:09am
Awesome mate! Have a good one!
We need more SPL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2019 at 12:25am
Quote But what were your inputs!? I cant seem to make a single horn sim similarly to 6 coupled punisher
You make a single segment horn that resembles your Punisher, with or without extension, exponential gets very close. Multiply S1, S2, Vrc, Vtc and Atc by a factor 6. In the input screen go to Tools - Loudspeaker Configuration - Set 6 drivers with series/ parallel. Adjust Eg for new impedance.
Phil B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil B Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2019 at 9:25am
You could make that a flat pack with a bit of thought ? Our main issue was attaching the extension to the subs in the same place every time. Our subs are Top and bottom L+R with interlocking skids so they stay in the same position. We also always try to stack on the same pallets we carry.
The extensions all just clip on with the latches starting with the bottom panel then sides, top and braces last. Those latches have a screw adjustment so can be adjusted if things aren't totally level. Every joint edge of the extension panel has a wood batten with foam to make a rattle free fit
Over the years we can now build them pretty quick, solve any rattles with a quick test track and pretty much forget after that ... I would like to add a horizontal brace at sometime but can't find any of that elusive time stuff kicking around !
AND they pack neatly into the trailer ...
.p.
Edited by Phil B - 29 November 2019 at 9:27am
citizensc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2019 at 9:22am
Update:
I have made cut sheets and solidworks drawings for this, there are two versions, one to fit a double punisher mk2, and another, 15mm wider to fit 2 x single punisher mk2s. I have removed the strapping points from the drawing, going to leave it to the builders to design a method of attaching it to the punishers.
I am not exactly experienced with autocad/solidworks and made these using trial versions of the software... I have done my best but would love suggestions for how to improve the drawings and make them more accessible so anyone can read and understand them.
Here are the files - please check them before you build anything from them, just make sure the cut sheets match the drawing and the drawings are the right width to fit your punishers.
PDF is for the double punisher version but you can apply most of it to the single punisher version just add 15mm to the width - https://www.dropbox.com/s/k56cocuhx4ym1aw/p-extension%20-%20double%20drawing.pdf?dl=0
Also does anyone know what software was used to generate this PDF? I would love mine to be that detailed and clear https://www.dropbox.com/s/djam4g1oqirwmsj/TH18%20Xoc1%20%2B%20CUT%20LIST.pdf?dl=0
If you have any feedback or questions please comment or message me! and feel free to make your own modifications to the design - I consider this open source.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2019 at 1:01pm
It is good to read (yet I am not surprised)that you are pursuing this project. Based on your replies, it was obvious you wanted to create this project. You might want to consider making a new thread in the Punisher and X-tro forum so no one will be looking for the design 10 years from now and, can't find it in the General Forum.
Best Regards,
This page was generated in 0.234 seconds.
