  New Posts New Posts RSS Feed - Punisher Extension Development Thread
Dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2019 at 12:09am
Awesome mate! Have a good one!
We need more SPL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2019 at 12:25am
Quote But what were your inputs!? I cant seem to make a single horn sim similarly to 6 coupled punisher
You make a single segment horn that resembles your Punisher, with or without extension, exponential gets very close. Multiply S1, S2, Vrc, Vtc and Atc by a factor 6. In the input screen go to Tools - Loudspeaker Configuration - Set 6 drivers with series/ parallel. Adjust Eg for new impedance.
Phil B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil B Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2019 at 9:25am
You could make that a flat pack with a bit of thought ? Our main issue was attaching the extension to the subs in the same place every time. Our subs are Top and bottom L+R with interlocking skids so they stay in the same position. We also always try to stack on the same pallets we carry.
The extensions all just clip on with the latches starting with the bottom panel then sides, top and braces last. Those latches have a screw adjustment so can be adjusted if things aren't totally level. Every joint edge of the extension panel has a wood batten with foam to make a rattle free fit
Over the years we can now build them pretty quick, solve any rattles with a quick test track and pretty much forget after that ... I would like to add a horizontal brace at sometime but can't find any of that elusive time stuff kicking around !
AND they pack neatly into the trailer ...
.p.
Edited by Phil B - 29 November 2019 at 9:27am
Solar & Wind Sound System Shennanigans..http://diyhifi.biz/
This page was generated in 0.090 seconds.
