  New Posts New Posts RSS Feed - punisher help
punisher help
abrupt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Topic: punisher help
    Posted: 03 July 2008 at 8:42pm
how easy would it be to change the v1s to stop them blowing
i thought about taking them apart and maybe put in place a aly sheet at the bk of the chamber to take away the heat
help please
(SoundcreationaudiO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote (SoundcreationaudiO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2008 at 9:15pm
replace the hatches with ali 3/4mm sheets cut to the profile...  plus one on the back for good measure if cabs stacked on sides..
taking apart a built cab will be bloody difficult, and destructive..  if good glue has been used..  laminates will be ripping..
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2008 at 10:49am
Replace the Ciare with a lighter coned and more efficient driver so you can use less power.  It would change the character of the Punisher, probably not so capable at the bottom end but maybe more kicky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2008 at 11:57am
how about just run a k through rather than hammering them all night
and what cones would you suggest
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2008 at 12:19pm
Yeah, the obvious way to stop them overheating is to run less power into them.
I tried drivers like the B&C 12TBX100 in simulations and the response looked generally flatter and slightly more efficient.  I reckon it's worth an experiment.
In answer to one of your questions on another thread.  I tried my Punishers (when I had them) up to about 140Hz.  They start needing a bit of EQ at the top end but 120Hz is definitely ok, maybe a bit higher depending on what music/midtops etc.
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2008 at 6:25pm
The brace is in the way directly behind the magnet so extending that way is going to be difficult, can you not recone the MK1 drivers rarther than use MK2 drivers?  That would give more space.  Fane collosus 12MB looked good on a sim as i remember, should sound tighter but wont go quite as loud.  Its got a fairly solid mullur (spelling?) cone so i recon it should survive if you dont drive them too hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2008 at 7:03pm
Colossus 12MB probably wouldn't be on my list....
B&C, 18Sound, Beyma all do a big 12" Sub driver with the same magnet as their high end 18" drivers.  That's the sort of thing I'm talking about.
