punisher horn length |
numtie
Young Croc Joined: 06 November 2008 Location: wales Status: Offline Points: 585 |
Posted: 24 November 2012 at 11:27am |
as the title states whats the horn length of the punishers both versions?
Disco Hire Wales
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
Walt, the designer claimed near 2 meter with the mouth exit to the floor. On itself (placed on the side) it's somewhat less, 1m70-1m80, give or take.
Timebomb
I have 2.3m in my hornresp sim, ill check tomorrow but its def longer than 1.8m, path length corner is about 40hz from my measurements.
inter-sound
Young Croc Joined: 20 April 2011 Status: Offline Points: 526 |
So does anybody have the EXACT length just to make sure our delays are spot on :).. Also anybody got any eq preferences with the punishers we run ours 38-90 24 L-R both ends.. I read sumwher a few db boost between 42-45 is worth a go . Think I'll hav a play this weekend
MusicXtra
Registered User Joined: 05 August 2009 Location: Netherlands Status: Offline Points: 249 |
If you want to have your delay 'spot-on' you really need to measure with Smaart or a simular program. (It's not the delay what's important but the phase of the sub and the mid around the x-over frequentie.)
inter-sound
this is something i need to get my head round i posted about it the other day and somebody said aslong as the time/distance delay was correct ther will be no phasing issues? can u link me to something explaining this further? |
MusicXtra
It's not that simple.
It depends of lot's of things. By example; an 18" front loaded subwoofer shall have a complete different phase behaviour than a 12" Punisher. Without phase filters it is impossible to combine these two with each other. I don't have a good link with a good explanation for you. |
inter-sound
i didnt think it was as simple as matching the time delay, things are never that easy. if anybody has a link to previous threads explaining how to overcome this problem and get the best results it would be appreciated
MusicXtra
The best and easyest way to time align a sound system is with a measuring program like Smaart.
