Punisher responce... |
Jay Lawless
Joined: 22 August 2005 Location: United States Status: Offline Points: 1702 |
Topic: Punisher responce...Posted: 09 September 2005 at 3:41am |
If I have two punishers per side, will it give me a good 40hz?
If not, how many will I need, and what would 2 per side give me?
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist |
Contour
Posted: 09 September 2005 at 4:06am |
Hello, A stack of two will offer 40Hz but at very high SPL levels I would recommend to set the lowcut at around 40Hz and boost about 3dB at 45Hz for the best performance. Remember the cone excusrion goes up quite rapidly below 45Hz. When powering them with 1600W a piece there is always the danger of over excursion when you don't use a proper lowcut. That could cause damage to the driver. The very low distortion of a horn makes it difficult to hear when the driver cannot handle the power anymore. Best regards, Walt |
Jay Lawless
Posted: 09 September 2005 at 3:11pm |
what would you sugjest me to use for a lowcut 40hz and a db boost? I'll
have 4 punishers being powered by two QSC PLX3402 amps. They have a
30hz cutoff witch im sure isnt enough.
Tom Umney
Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Posted: 09 September 2005 at 3:20pm |
50hz cutoff I'd use just be on the safe side as I cain the f**k out of my speakers. And because i'm lazy and poor
Contour
Hello, I assume you use some sort of crossover/processor to drive the amps with the sub signal. Most processors offer an ajustable lowcut. The lowcut depends on the number of cabinets and the placement (outdoors, indoor, cornerloaded) I would start with 40Hz and the boost at 45Hz for two punishers a side. From there you can experiment which sounds the best in your ears. Some music doesn't require 40Hz in that case you might find a 48Hz lowcut gives you most power. I use a Punisher in my small room as cornerloaded hifi subhorn. I don't use much power, 10W is enough to shake the room. I have used a 8dB boost at 30Hz. What I am trying to say is that the optimal settings depend strongly on the way of using them. Best regards, Walt |
Jay Lawless
Posted: 09 September 2005 at 9:15pm |
We've decided to use 4 Punishers per side. Most of the time the use
will be indoors. We'll be getting a Legion Sound 24 channel mixer
board, I'll take a closer look at it but I think it has an ajustable
lowcut on it. I know Legion isn't the greatest, but it's good enough
for us.
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8800 |
Posted: 12 September 2005 at 8:22am |
Be aware that the QSC 50hz filter provides a boost in the region prior to cutting. Not sure of the figures but make sure you check it out before going ahead
