  New Posts New Posts RSS Feed - punisher
punisher
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 4:47am
walt, i notice that your colleagues have used 7 laminate ply in those pictures
(presumably an availability/cost thing). do you know if the choice of material
has had any effect on resonances etc?
james.
mardy hippy.
Charles_V View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles_V Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 9:27am
I am planning to build 8xpunisher horns and 4xtro to complete the
system.
Is there as distributer for the ciare driver in the uk? or is it best to go
direct
to ciare?
Also where is the best place to put inspection holes in the x-tro
I have drawn the plans up on some software I use for work (IV10 Pro). I be
happy to share them If any wants to see them. I can export .dxf. dwg -
the Acad type files.
below is a rendering from my software. Hopefully I will have something
like that at the end!
cheers, and happy hopping.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 9:55am
trully mind blowing
the ciare distribuitor in UK is proaudioparts - see the banner on the bottom of this page
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 1:41pm
very good, although you've missed out the beyma 245s! they are mid tops
without the tops... i reckon you'd be getting all manner of comb filtering
problems arraying your tops like that but still, a brutal stereo. be nice to set
it up in a big room and do some real quadrophonic coolness.
james.
mardy hippy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles_V Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 3:28pm
245s!
james.
I know. I got all exited about making a big stack and left them off the
model.!
they are on there now though!
great thing about using software like inventor for this project - i've just
sent off a load of files to plonk straight into a cnc machine... so no
worries about wonky cuts there!
has anyone got into building their own amps? I work for an electronics
company at the moment and have access to some PCB layout software
and quite fancy giving that a go too!...
I have found a schematic for a 1000watt switchmode type amplifier - any
one know of a decent schematic for an amp suitible for powering this sort
of rig?
Cheers
carlos.
MixMan X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MixMan X Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 3:42pm
Let's have a look at the picture with the Beyma's in then, I want to use it as my desktop background!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MixMan X Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 3:44pm
Just to add, do you think you wouls have problems with comb filtering with two stacks of four Punisher's and two Xtro's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles_V Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2006 at 7:43pm
To be honest I have n't a clue! I'm going for the "suck it and see" approach.
Edited by |carlos| - 22 January 2006 at 7:45pm
loophole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2006 at 6:10am
james is talking about the comb filtering you're going to get if you place all the xtros in one straight line like that. they all have carefully controlled dispersion, and need to be placed splayed apart to avoid interference
angus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote angus Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2006 at 2:13pm
@carlos
I'm no stranger to elctronics myself and I think you would be /very/ hard pushed to make a better sounding and cheaper amplifier than you can buy off the shelf, even with access to make free PCBs. It's all down to the volumes of production, professional design teams and years of experience that amplifier manufacturers have at their disposal.
Jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2006 at 4:45pm
I've got a "pen pal" of sorts in Texas that is building his own amps.  I think he visits this forum, but I've never seen him post.
Warren?
Jim
