punishers powered by ep2500 |
Page <12 |
IAIN RENDLE
Joined: 23 May 2005 Location: United Kingdom Status: Offline Points: 836 |
Posted: 02 July 2007 at 8:53am |
if you are gonna push 1500 into a punisher i would recomend that you raise the HPF to atleast 40hz... i began to hear mine bottoming out when pushing 1200watts through them with a HPF at 35hz. yeah defo get a better amp. that behringer amp will prob die in the next week or 2 if your giving it a hard time.
whats your budget????
-=vortex sound systems=-
www.vortexsound.co.uk |
okey
Joined: 02 June 2006 Location: Sweden Status: Offline Points: 31 |
Posted: 03 July 2007 at 3:52pm |
budget is ~ 800€ and i also want it to be a light weight amp...
Rengade Project
Joined: 12 December 2004 Location: United States Status: Offline Points: 601 |
Posted: 05 July 2007 at 1:44am |
Hail okey the XS-1200 is a good amp I own two .I bought the second due to the performance of the first one and there are good bargains on them now as they are discontinued.
MUSIC SWEET,www.myspace.com/renegadeproject
pysos
Joined: 03 August 2007 Location: Germany Status: Offline Points: 11 |
Posted: 03 August 2007 at 11:25pm |
Check out DAP Vision 3500 or T.amp proline 3000
http://www.thomann.de/de/tamp_proline_3000.htm |
A&O Audio und Showtechnik
http://www.ao-audio.de |
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8800 |
Posted: 04 August 2007 at 7:45pm |
You could pick up a PLX3402 or maybe a PLX2 3602 for that money. Put out easily enough in bridge mode to power a pair, and they're switch mode so lightweight.
soundsystemdan
Joined: 04 April 2005 Location: Leeds UK Status: Offline Points: 716 |
Posted: 05 August 2007 at 11:46am |
without spending money, you could use the 50Hz hpf instead of 30Hz. Also, instead of switching it off to let it cool down, leave it on so the fan stays running and turn the gains down.
kpippen
Joined: 04 July 2007 Location: United States Status: Offline Points: 174 |
Posted: 05 August 2007 at 7:08pm |
I've been biting my tongue on this thread for sometime now...but since it's been resurrected I'm going to jump in.... The EP2500 is rated for 2400 watts at a 4-ohm load in bridge-mono… A popular amplifier sizing rule of thumb recommended by several manufacturers is 2.5 X the continuous rating of the load… I’m not certain what the continuous power rating of the Ciare 12.00SW is…but I would guess it’s somewhere in the neighborhood of 650-700 watts (I might be too conservative)… This would calculate to approximately 1300 to 1400 watts at 4-ohms for two Punishers… I recently installed nine EP2500s and it's a killer amp for the $money$ ($278.00USD)...but it's underpowered for a Punisher loaded with the Ciare 8-ohm driver... Kevin
Edited by kpippen - 06 August 2007 at 2:28am |
turn on, tune in, drop out
Hey Nipper,...we gotta have more cowbell!!! |
Page <12 |
