  New Posts New Posts RSS Feed - Q12  12" Sub
Q12 12" Sub
 Post Reply Post Reply Page  <1 34567 13>
Edd Jordan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edd Jordan Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2011 at 5:45pm
Oh it works but its the input sensitivty be not what they said it was . Anyway never mind its on its way back to dsp to be moded.
End of this year going to be building a new system might go the same rout as you liking the small scale big sound factor! Thumbs Up
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2011 at 6:06pm
OK, I have a few more projects involving small, loud and High quality so keep in touch :)
Tony
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2011 at 3:40am
Great little sub Tony :) I don't know how you do it, simple but absolutely stunning cabs.
How do you guys get real world plots? Using Smaart? I want to do my 12" white subs as they sound lovely and drop low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2011 at 11:18am
SamV,  I suppose 20 years as an industrial designer must help + I like to keep things nice and simple as long as it does not inhibit performance.
The main tool I use for quick plots is Real_RTA  I find it just as accurate as the more expensive programmes that I have access too.  I use it with a berry ECM8000 as I mainly do comparison checks for which this is perfectly OK.
An Earthworks mike is probably on the cards in the next few months.
Tony
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2011 at 2:08pm
But does it supply the plots in graph form?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2011 at 2:18pm
Yes it does, you can save the plots to a series of memory positions for comparisons.
If you download the demo version you can see how it works but only in 1 octave resolution. It will work with your laptop mic if you have one (not for proper use).
If you register with these guys you can also download the latest version of Room EQ Wizard 5 for free which also does what you want.
http://www.hometheatershack.com/forums/rew-forum/
Tony
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2011 at 2:36pm
I have proper mics I can use which are flatter and more directional than the ecm8000. I'll check out the software.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2011 at 10:54am
A few detail pics of my latest pair.
kevin tyler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin tyler Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2011 at 2:28pm
NICE!
subbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2011 at 2:36pm
its all about the detail Clap
ermita View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ermita Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2011 at 2:38pm
Nice one Tony, looks like an easy build too only 6 piece of wood. Any chance of measurements could be a next project for Home theater useThumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin tyler Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2011 at 4:32pm
nice job tony,
here is my latest build
beyma 12 subs and 12 tops, all neo apart from the old de750's in the mids
small is the new big
