  New Posts New Posts RSS Feed - Q12  12" Sub
Q12 12" Sub
 Post Reply Post Reply Page  <1 10111213>
jjoakim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjoakim Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 9:43pm
So are the cabs "better" than bose 502b. I would think only bad thing that 502b is that they wont go under 50hz :( and they are heavy.
What's the dimension of twin?
What amp they need? Does my t.amp 4-700 cover it?
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 9:59pm
they will put the bose to shame..  you would need an amp capable of 1600 watts at 4ohm. for the double version, the q12 plays 40hz low end may be a tad lower
Edited by bee - 23 September 2018 at 10:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjoakim Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 10:03pm
What speaker driver?
Safetyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Safetyman Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 10:24pm
The ones in the pic on page 4 I use with a Matrix XT 6004EQ( 4x 1,200w/4r ) with DB Mark 2in-4out sound system processor. The F208's are rated @ 400/4r, and the F212B's @ 1,200/4r. According to Tony, at the time, the top cabs would handle around 800-900w each and the bins around 2,000w each. I believe the tops are around 99db sensitivity for 1 watt/ @ 1 metre, and the bins are 96db and go down to 32hz. Both designs have 2 rear ports on each cab. So, the performance of a single 18inch, with a very small footprint and incredibly loud for their size.
Protect your hearing, and feel the music.
MU South East Roving Safety Rep.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 10:39pm
bms 12s330 or the neo version, bms 12n630
Edd Jordan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edd Jordan Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 1:13am
Good man Bee
They require alot of driving the dual q12 could take 2000watts a bin. mine do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjoakim Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 6:12am
bms 12n630 is not so expensive, I think.. about 250€
If driven with 8ohms, does it require more than 600watts?
As 502 is 450watt rms 1600 watt peak, manufacturer recommends 1200watt amp. I use my t.amp tsa 4-700 in bridge mode at 2x1600w/8ohms. It is capable to 2x1800w/4ohms but thomann said that there is sometimes stability problems in bridge mode @ 4ohms. It gives 4x490w/8ohms, 4x810w/4ohms.
Once I ordered 18" 450watt sub, and thought it needs same power, or atleast x2 but when I played with it. It started to smell like burned electric.
EDIT: So, I sent the 18" sub back.
Edited by jjoakim - 24 September 2018 at 7:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Safetyman Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 7:21am
My bass bins have the neo version 12 inchers, while the tops have the ferrite version of the 8 inchers. The bins weigh 29.6 kg, while the tops weigh 16 kg. The neo version of the 8 inchers only reduce the weight by, apparently according to Tony, some 2kg per cab, while the ferrite version of the 12 inchers increase the weight by around 5-6kg per cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjoakim Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 11:02am
bee I sent you pm yesterday
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 5:40pm
defo did not get it m8t, try again now you have 10 post, think pm don't work unless you have 10 posts..
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 5:42pm
Originally posted by Edd Jordan Edd Jordan wrote:
Good man Bee
depends on were you are setting the hp and lp on the box. 1000 watts per driver also sounds about right, using a higher hp slope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjoakim Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 6:03pm
So, even the driver is only 600watt rms, how much it can handle?
And is it that, how much there is "back pressure" from the cabinet the driven can handle more?
This page was generated in 0.096 seconds.
