Q12 12" Sub |
Page <1 111213 |
bee ![]() Old Croc ![]() ![]() Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
bms rate there drivers as they should be rated, not in peak figures. So the driver is 600w but can take peaks of a lot more. an amp that can do 1000w at 8ohm would be fine with a single driver. for the double based on 8ohm drivers your need an amp that can do 2000w at 4 ohm.
jjoakim ![]() Registered User ![]() Joined: 16 September 2018 Location: Finland Status: Offline Points: 24 |
Ok, then I can use my current amps..for subs 4ch tsa 4-700(2x1600w@8ohms) and 2ch tsa 1400 for tops(bose 802),
For smaller gig I can use that 4ch amp, tops and one sub. As if Q12 covers the 802(91dB-SPL (1W, 1m)). |
Edd Jordan ![]() Young Croc ![]() ![]() Joined: 10 January 2008 Location: United Kingdom Status: Offline Points: 1358 |
spot on
Spinblitz ![]() New Member ![]() ![]() Joined: 10 May 2021 Location: Norfolk Status: Offline Points: 1 |
Hi Guys,
This size of project is just what I've been looking for, I don't have the space or really the requirement for a larger system but this would be enough to satisfy my itch and keep me out of trouble. So that being said, is anyone able to share the plans please? Bee, I'd be more than happy to donate in Tonys name if you still have them. Any help is greatly appreciated. |
markie ![]() Old Croc ![]() Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4564 |
Bee is Ben at Elements Audio, but he hasn't visited the forum since February.
Suggest you contact him direct.
Page <1 111213 |
