  New Posts New Posts RSS Feed - Q12  12" Sub
Q12 12" Sub
 Post Reply Post Reply Page  <1 111213
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 6:54pm
bms rate there drivers as they should be rated, not in peak figures. So the driver is 600w but can take peaks of a lot more. an amp that can do 1000w at 8ohm would be fine with a single driver. for the double based on 8ohm drivers your need an amp that can do 2000w at 4 ohm.
jjoakim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjoakim Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 7:18pm
Ok, then I can use my current amps..for subs 4ch tsa 4-700(2x1600w@8ohms) and 2ch tsa 1400 for tops(bose 802),
For smaller gig I can use that 4ch amp, tops and one sub. As if Q12 covers the 802(91dB-SPL (1W, 1m)).
Edd Jordan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edd Jordan Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2018 at 11:13pm
Originally posted by bee bee wrote:
Originally posted by Edd Jordan Edd Jordan wrote:
Good man Bee
They require alot of driving the dual q12 could take 2000watts a bin. mine do.
depends on were you are setting the hp and lp on the box. 1000 watts per driver also sounds about right, using a higher hp slope.
spot on
Spinblitz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spinblitz Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 11:52am
Hi Guys,
This size of project is just what I've been looking for, I don't have the space or really the requirement for a larger system but this would be enough to satisfy my itch and keep me out of trouble.
So that being said, is anyone able to share the plans please?
Bee, I'd be more than happy to donate in Tonys name if you still have them.
Any help is greatly appreciated.
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 4:04pm
Bee is Ben at Elements Audio, but he hasn't visited the forum since February.
Suggest you contact him direct.
This page was generated in 0.110 seconds.
