Q12 12" Sub |
Page <1 34567 13> |
Edd Jordan ![]() Young Croc ![]() ![]() Joined: 10 January 2008 Location: United Kingdom Status: Offline Points: 1358 |
Oh it works but its the input sensitivty be not what they said it was . Anyway never mind its on its way back to dsp to be moded.
End of this year going to be building a new system might go the same rout as you liking the small scale big sound factor!
Tony Wilkes ![]() Old Croc ![]() ![]() Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 4840 |
OK, I have a few more projects involving small, loud and High quality so keep in touch :) Tony |
SamV ![]() Old Croc ![]() Joined: 21 October 2008 Location: London Status: Offline Points: 8707 |
Great little sub Tony :) I don't know how you do it, simple but absolutely stunning cabs.
How do you guys get real world plots? Using Smaart? I want to do my 12" white subs as they sound lovely and drop low. |
SamV, I suppose 20 years as an industrial designer must help + I like to keep things nice and simple as long as it does not inhibit performance. The main tool I use for quick plots is Real_RTA I find it just as accurate as the more expensive programmes that I have access too. I use it with a berry ECM8000 as I mainly do comparison checks for which this is perfectly OK. An Earthworks mike is probably on the cards in the next few months. Tony |
But does it supply the plots in graph form?
Yes it does, you can save the plots to a series of memory positions for comparisons. If you download the demo version you can see how it works but only in 1 octave resolution. It will work with your laptop mic if you have one (not for proper use). If you register with these guys you can also download the latest version of Room EQ Wizard 5 for free which also does what you want. http://www.hometheatershack.com/forums/rew-forum/ Tony |
I have proper mics I can use which are flatter and more directional than the ecm8000. I'll check out the software.
A few detail pics of my latest pair.
kevin tyler ![]() Old Croc ![]() Joined: 15 April 2007 Location: Spain Status: Offline Points: 3394 |
NICE!
subbass ![]() Old Croc ![]() Joined: 30 March 2009 Location: bristol Status: Offline Points: 1683 |
its all about the detail
ermita ![]() Young Croc ![]() ![]() Joined: 19 August 2010 Location: Surrey, TW10 Status: Offline Points: 1266 |
Nice one Tony, looks like an easy build too only 6 piece of wood. Any chance of measurements could be a next project for Home theater use
nice job tony,
here is my latest build beyma 12 subs and 12 tops, all neo apart from the old de750's in the mids
small is the new big
Page <1 34567 13> |
