QSC PL380 vs QSC PL9 vs Powersoft K20 |
Post Reply | Page 123> |
ReubGold
Registered User Joined: 09 April 2012 Location: Essex/JA Status: Offline Points: 271 |
Posted: 10 September 2019 at 12:31pm |
From what I've seen: Powersoft K20 - Not warmest sound @ 2.66 ohm stereo, but plenty power, most reliable, decent power on 32A ring main QSC PL9 - Most powerful when on Genny, most unreliable, fairly warm sound, often blows on 32A ring main QSC PL380 - Ok reliability, warmest sound, ONLY really performs on Genny, or very strong mains spur. Comment, opinions, thinking of trying Crown MA12000.
If he turns me into a zombie, first person I'm coming after is you.
spongebob
Young Croc Joined: 20 October 2010 Status: Offline Points: 1395 |
"Most powerful when on Genny"
levyte357-
Maybe should say, performs best when on Genny. I have seen this many times.. |
rosssss224
Registered User Joined: 25 July 2012 Status: Offline Points: 447 |
Is there any benefit running a K20 off anything other than a 13A standard socket if only running at 4ohms? In this case to power 4 PD1850's playing 30-85hz.
Looking at the fuse curve I can't see there being much point.
levyte357-
Can't see the point of running 1850s downto 30hz, in most cabs. Can forsee many disadvantages, and problems of doing it though.
All QSC amplifiers sound the same. If the Powerlight 380 sounds "warmer" to you than the Powerlight 9.0, it usually stems from one amplifier running out of headroom faster than the other (which begins to clip). When this occurs, distortion (Not at all times a bad thing when you are aiming for a particular tone) is coming into play. The above is very common when comparing two amplifiers of the same brand offering unequal output power. The QSC Powerlight 9.0 is 9000 watts RMS whereas, the QSC Powerlight 380 is 8000 watts momentary (Burst) Peak. Best Regards, Edited by Elliot Thompson - 11 September 2019 at 2:51am |
toastyghost
The 10,000 Points Club Joined: 09 January 2007 Location: Manchester Status: Online Points: 10919 |
Where you should place your electronic HPF is very rarely where the acoustic output has dropped by 3dB. The HPF should prevent overexcursion but also aid cooling, and many reflex boxes can also take a large PEQ boost at tuning frequency too. You’d be very surprised if you saw many pro manufacturers’ settings, for any sort of design. They very rarely match what I see used in the DIY scene. As for using a bigger mains plug, you should use the largest available, for thermal reasons if anything. A 13A plug fuse may not blow but the wire is thin comparatively and the plug top will get warm. Edited by toastyghost - 11 September 2019 at 10:06am |
Chris Grimshaw
Registered User Joined: 10 September 2018 Location: Sheffield Status: Offline Points: 281 |
I have an MA12000i sitting around at the moment. Would be interested in selling it on. PM me if you'd like to work something out. Chris
Quality sound from Sheffield
www.grimshawaudio.com |
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
QSC PL380 is a crap Class-D, does not even have real output feedback.. Very poor sound quality. Its PSU is also a nigthmare for circuit breakers, poisoning the mains with extreme current spike harmonics. QSC PL9.0 is a half-finished yet over-complicated design. Not reliable, since ~10 or more years out of production, not a surprise! Powersoft K20 is not sounding good but still works better than the two above^
rosssss224
Intrigued what's good sounding then?
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2126 |
I have never seen you ever make a positive comment about any amp ever, pure negative vibes. We all know you are involved with PKN in some capacity but the product bashing is really getting tiresome now. I use the PL380 to drive my subs, I really like it, loads of power, spanks PD1850 right to their limits and most importantly sounds clean and good. I regularly run 6 drivers off it on a 32amp supply and have never had it pop a breaker even when being drive right up to clip. Personally I think it sounds a lot better than the K20 which I have also played with. TBH I have never been a fan of the Powersoft K series when it comes to tone, oodles of power but the tone is just not for me. |
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
levyte357-
Have to agree with 99% of that, PL380 on proper mains/genny can properly spank 6x PD1851s, with warmth and tone. K20 loses bit of warmth, when you play > 2 "8 ohm" cabs a side. But K20 is possibly the most likely amp to survive heavy gig, at 4x cabs a side. Notice I didn't mention terms like 4 ohm/2 ohm stereo, as most cabs are never 8 ohm exactly.
