Quad 12" Isobaric Ported Sub |
Post Reply | Page <123> |
Author | ||||
darkmatter
I think you simply need to download and install the font "MS Sans Serif Regular".
snowflake
why only good to 50Hz - surely that depends on the drivers and size of box? |
FrederikMA
Registered User Joined: 19 July 2017 Location: Copenhagen Status: Offline Points: 76 |
Void Nexus X goes to 36Hz -3dB http://voidacoustics.com/docs/products/Nexus_X.shtml Edited by FrederikMA - 01 August 2017 at 5:14pm |
Where did you see it says it is a Manifold? The Manifold is a patented design from Electro-voice from the 1980's that uses 4 or 2 18-inch Drivers. Best Regards, |
snowflake
you can see the manifold mounting on the picture in the link above. I haven't read the whole EV patent but I wouldn't think they would have limited it to 18" drivers, would they? patent will have expired by now anyway. |
I do not see an internal picture of the design so, I am not going to assume it is indeed a Manifold. From historical standpoint, Rog tends to create his own designs (with great pride) despite from a spectator point of view it resembles another design when it comes to bass cabinets. A prime example is the PD 1850/186 and the Cerwin Vega B 36. Best Regards, |
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 561 |
The EV Manifold Technology is pretty much just about considering a moving diaphragm as a piston and loading them into a Manifold so as to unify their output. It's used on the HF and MF units from the MT series, its not solely an LF principle, nor is it restricted to 18" drivers. Turbo did something very similar with the V2 device on the later TMS-3s... Which, amusingly, used the same HF driver as some of the MT series HF units yet achieved a much better result (at the cost of expense) |
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 623 |
B36 and 186 horn have different folding.
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
But from a spectator view (the outside) they might look the same, which is the point Elliot is trying to make.
That being said, you can see the drivers in the central (manifold chamber), that are mounted as they would in a manifold, you can see the ports and there's only about 40 litre per driver to play with, so there isn't exactly much else you can do that makes sense. The patent has expired and he is the first to cram 8 x 12" drivers in such a small enclosure. Let's ask Aman Gebru! |
cravings
Old Croc Joined: 30 January 2007 Location: Ireland Status: Online Points: 7442 |
i think that was the point elliot was making. that at a glance, they might appear similar. but they're actually different.
FrederikMA
So in the search for a high cabinet size to output ratio I guess it's about finding drivers with suitable Thiele Small parameters for a small volume reflex manifold or finding drivers with higher sensitivity to compensate for the reduced sensitivity of the isobaric loading. In practice i would suspect the reflex manifold to win out on sheer output to cabinet size, disregarding the allegedly reduced distortion of some kinds of isobaric loading.
snowflake
I thought people were saying they didn't know what was inside (although it seems likely they are a bass-reflex with manifold mounting). |
