Quad 12" Kick Sub |
Post Reply | Page 123> |
stalian87
Registered User Joined: 16 March 2015 Location: United Kingdom Status: Offline Points: 110 |
Posted: 27 February 2018 at 5:01pm |
Hey Everyone,
Just thought i'd share my design of a quad 12" sub I've been working on for about 9 months now. I've built it and it works like a charm. It's actually more compact than it looks and gives an amazing punch at 80hz reaching a max of 133db (not bad). I must add that as it was the first I built, there was lots of air leakage due to my handy work so it can defo go louder. The design has been heavily updated since the first build to make it easier to put together and make it air tight. it can be used as sealed or poted. you can download the sketchup file from my Gdrive: https://drive.google.com/open?id=1KXTnaka1IwqpCu9VaSSPH0g3pi38oENc
djeddie
Nice one! Design something and build it... instead of leaving it on paper as lots of us do!!!
Have you done any measurements on it yet? Or even a SIM? |
stalian87
thanks! yeah building it was a bit of a challenge due to the silly angles of the baffles but my CNC guys did a good job, albeit certainly charged for it!
i did a sim before building it of course and was pretty much spot on when blasting it in the studio! but i didn't save any measurements on the day. once i build the next one, i'll do some proper measurements. I'll post the sim on here in a bit
djeddie
Trying to work out form the pics, is it a sealed cab or reflex?
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1085 |
Do you have any measurements?
stalian87
it can be used as both with the centre plug screwing on and off with bolts
no measurements as I already mentioned but will get them done on my next build
stalian87
cravings
Old Croc Joined: 30 January 2007 Location: Ireland Status: Online Points: 7441 |
cool project! great stuff.
stalian87
thank you, much appreciated. i really hope i'm contributing to a community which has helped me a heck of a lot in the past.
smitske96
Did you mount the drivers before mounting the BR port?
stalian87
no there was plenty of room to mount them after installing the port walls.
aleksmla
New Member Joined: 04 March 2014 Status: Offline Points: 2 |
