Quadraphonic System's |
re-production
Registered User Joined: 16 February 2017 Location: Suffolk UK Status: Offline Points: 176 |
Posted: 19 February 2019 at 2:41pm |
Hi Speakerplans,
A client has asked for a Quadrophonic system in a small room (200 cap), does anyone have any tips for setting a quadraphonic system up? Is it best to not delay the system at all? Do you want each stack to be doing the same Freq response or would it be better to have the rear speakers acting as fills? It's for disco music played from CDJ's, the system will be Res 2 and F218 with separate EQ and delays on each output of the system. Thanks in advance!
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1833 |
what does your client mean by quad?
double stereo stereo from the mains, spatial information from the rear 4 discrete channels with panning joystick
LOUDER THAN LOUD
4D
Quite. joystick driven quad as Tony will tell you involves folk running up telling you that the speaker over in the corner has stopped working we used to do 4 stack configs with the rear pair running a reversed stereo signal which works reasonably well especially if you can fly the tops and keep the subs in a mono block close to the booth another thing was symmetry ie: perfect square then you can keep the levels equal otherwise working in a rectangle there is a lot of judicious faffing with gains & delays and there will always be somewhere in the room where its out of synch and all a bit clattery with the bass/low mid either summing or cancelling... so square room its do-able rectangular room its a compromise and often it is preferable if you can do true stereo with delay stacks for the rear of the room.
mini-mad
Does sound like an awful waste of time...
How many times have anyone here every had a punter come up to them half way through a gig a comment on how fantastic the stereo separation is on their system? Quadraphonic sounds way too 70s to me. I'm guessing the owner is also the DJ and is aiming for something he thinks will sound "cool" but when the room is full of half drunk/high punters... no one will care. Set up as stereo... with delay stacks at the end of the room and tell him its quadraphonic.
