Quick question on passive radiators. |
TheORig
Registered User Joined: 18 June 2018 Location: Bristol, UK Status: Offline Points: 30 |
Posted: 23 March 2019 at 2:26pm |
Hi, Just a quick question on passive radiators.
I understand that the surface area of the passive radiators has to be around twice that of the active driver but which would be the best combination when building a 10" subwoofer and why? (Assuming the enclosure is a cube of the appropriate volume) 10" driver with 2x 10" passive radiators on either side. 10" driver with 2x 12" passive radiators on either side 10" driver with 1x 15" passive radiator on rear. Thanks in advance
Edited by TheORig - 23 March 2019 at 4:48pm |
snowflake
it depends on how much travel there is in the passive radiator suspension
Chris Grimshaw
Registered User Joined: 10 September 2018 Location: Sheffield Status: Offline Points: 281 |
Assuming equal Xmax, 2x 10" or 1x 15" would be fine. 2x 12" would be overkill, but if you have a particularly powerful active driver and the 12"s don't have so much Xmax, it'll probably be about right. Dual passive radiators give you the option for force cancellation, so 2x10" would get my vote. Chris
Quality sound from Sheffield
www.grimshawaudio.com |
