Quick question |
Post Reply | Page <1234> |
Author | |||
vertx
Young Croc Joined: 14 March 2012 Location: Sydney Status: Offline Points: 578 |
Many other variables I know but my Soundstandard CA18s clipped earlier on overloaded 10a Australia circuits than 10a circuits where they were the only thing connected. Why I do not know but performance, at least subjectively, did differ. Is this voltage sag/drop that is causing this?
Edited by vertx - 27 September 2018 at 1:02pm |
www.instagram.com/translate.sound
Earplug
Yes, voltage sag on the primary obviously causes the secondary voltage to drop as well. So amps will not be able to give their maximum rated power and clip earlier. |
Fred_dibna
Registered User Joined: 24 September 2018 Status: Offline Points: 213 |
So find double wall sockets and then use one socket on each double socket for each amp? Is that what i'm understanding you said?
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
Yep.
Fred_dibna
And that increases the potential for about 19A/240V does it? I mean if the amplifier needs it.
dylan-penguinmedia
A 13a fuse doesn’t always blow at 13 amps - it will usually hang on until 17-18ish amps. The amp will take what it needs until this pops.
However, if you have 2 bass amps, both pulling 17a for example, and they’re off the same double socket, there will possibly be a fire. Either way you’ll probably damage the socket or look like a dick (or electrocute yourself) trying to prise the plugtop out of the socket when you’ve welded the pins in after a long session. So you move one to the next socket, not because of bass, but because of ‘not fire’ and ‘getting invited back’.
I-shen Soundboy
Registered User Joined: 21 December 2016 Location: Big Smoke Status: Offline Points: 375 |
A double socket can put out 19.5A - 20A continuous (the standards require it to handle 14A in one socket and 6A in t'other), but the plug has a 13A fuse (and then some...), so you're realistically limited by what the fuse will pass.
(The 13A plug rating is the level at which it'll dissipate 1W of heat, considered to be the safe limit. You can pull more until the fuse blows, but the plug tends to get a bit burnt / melty).
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2464 |
Im sure as others will testify you can draw allot more than 13A from a 3 pin domestic socket! Obviously sine waves are transient re.music contet so personally ive achieved peaks of 23-26A albeit with a Void infinite 8 mk2.
I-shen Soundboy
I've burnt out transformers and blown transistors, but I can't ever remember an amp failing because the fuse in the plug blew.
mini-mad
Testify brother... Testify!!!!
Fred_dibna
Ok thanks guys.
I-shen Soundboy
Sunny saturday at carnival, amps in full sun, suprised it didn't happen more often. Put them in shade with a fan on after that. It was a passive cooled NAD so I was asking for it... It appears to take special effort to pop a domestic.13a fuse.
