  New Posts New Posts RSS Feed - Quick question
Quick question
Silas )))))) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Silas )))))) Quote  Post ReplyReply Direct Link To This Post Topic: Quick question
    Posted: 19 June 2008 at 3:59pm
Do you put wadding behind the corner bracing on the 186 horn?
Cheers
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2008 at 4:01pm
as in the bottom corner?
or the top front? either way no I would fill the space with expanding foam.
insert silly sentence here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Silas )))))) Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2008 at 4:41pm
righty ho, cheers.
However if i dnt have any expanding foam...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2008 at 5:28pm
well its not essential, The expanding foam was just a "if you are going to"
But I would just to ensure shes as dead as possible [that sounded a bit wrong but hey!!!]
