  New Posts New Posts RSS Feed - Quick question
Quick question
G-Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G-Man Quote  Post ReplyReply Direct Link To This Post Topic: Quick question
    Posted: 05 November 2009 at 3:07am
Every pic I see has the scoops positioned driver up, or on their side, any reason you could not put the driver down? (upside down from the norm)
G
If it was easy, everyone would do it!
DjMidKnight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjMidKnight Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2009 at 3:25am
well with the cabinet right side up the horn path is extended by the ground, generally scoops are laid on there sides when stacking because it keeps the stack shorter. so yes they can be set upside down with no major downside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote G-Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2009 at 1:59pm
I was just thinking that it would lower the center of gravity and make them more stable.
