  New Posts New Posts RSS Feed - quick REW question
quick REW question
Norseman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norseman Quote  Post ReplyReply Direct Link To This Post Topic: quick REW question
    Posted: 10 September 2022 at 12:21am
im getting confused with REW time alignment process, whether to use loopback, or to follow this (easy looking)
tutorial..
https://www.youtube.com/watch?v=sNGSucheIy4&ab_channel=AtlosAudio
im also confused as many of the tutorials say to remove the crossover filters when running sweeps...so what happens here?  the driver just extends to its max reach and then stops firing as the sweep goes beyond its range?  my REW does not give me a pink noise option either, only a sine sweep...
ive read just about every thread on here and the links toastyghost et al have posted and im still bloody confused..
sorry chaps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norseman Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2022 at 12:38am
this guys methodology keeps the filter/crossovers, and seems logical...
https://www.youtube.com/watch?v=N9jXCIYDlw4&ab_channel=JohnHeisz-SpeakersandAudioProjects
he is using the alignment tool
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2022 at 2:12am
Conversely I came across advice to sweep the box as-is, full range with no filters or EQ, since what may happen out of passband will influence how you process the signal (ie, addressing nasty spikes, or factoring in natural rolloff)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norseman Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2022 at 2:14am
I don't understand that, if we already know where we want to cross over our cabs...surely you want to time align with regard to the chosen crossover frequencies or each cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2022 at 10:38am
If you're talking about actual time alignment, then this should be done without any filters in place. Use the IR rise time (not peak) or the group delay values for each driver (see Charlie Hughes' method for the latter, although you need good clean measured data).
This way, the sources are aligned, regardless of what else is put in place.
Then, your filters should be chosen to provide complementary phase response at your target acoustic crossover frequency. This may require asymmetrical filters - frequency and order.
If you go the other way round, you can be in phase but a lap or more behind. Or align to a reflection, or struggle to get an alignment at all because the phase responses of the drivers and filters are simply not complementary in slope angle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norseman Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2022 at 11:42pm
ok, thanks
so disable the crossovers, sweep each cabinet with no crossovers in place...
then perhaps play with the aligement tool to simulate the best order filter etc...or use align phase at cursor (where cursor is placed at the chosen cutuff freq for each crossover)
and transpose these results that look the best back to the DSP?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2022 at 1:19am
Don’t try to align the phase response at a single frequency. Time alignment is about ensuring the sources play at the same time.
Once that is in place, you then pick electronic filters which combine with the acoustic phase of each driver to produce a phase-matched response through the desired crossover region. Ideally for at least one octave either side of the target frequency.
Go back over the paper I linked from Charlie Hughes. Use either the group delay outside of the passband, or zoom right in on each windowed IR plot to find the time where it first begins to deviate from zero. That's your offset.
You might need to zoom the y-axis by 10x or more to really see it.
I’m not sure if REW can model various types of filters and orders to do the next part. If not, you might be better off taking the measured response of each source out of REW and throwing them into VituixCAD, which is also free. That will also show you the summed response of the delay and filters, for that given micnpositij.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norseman Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2022 at 11:05am
thanks mate.  i found the talk those slides are from, so will try and get more info from that and try again.
